Go to Post Originality in Sponsorship can get you a lot of places. - MysterE [more]
Unread 07-11-2004, 16:01
SCYTE16's Avatar
SCYTE16 SCYTE16 is offline
AKA: Gordon Tennyck
#0011 (MORT)
Team Role: Student
SCYTE16 is on a distinguished road
Question where can I get info on extruded aluminum?
I really need tech. specs and to find prices for extruded aluminum/plastic/other metals. I'm on the R&D (research and development) team for MORT (team 11) and i really need to find this. plz help. the R&D team just started this year so we have no places with info to just look it up so if you could help i would be very grateful or we will end up like this
Unread 07-11-2004, 16:05
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Re: where can I get info on extruded aluminum?
www.8020.net Beware the weight of this stuff really adds up.
Unread 07-11-2004, 16:24
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Bosch Rexroth extrusions.
Unread 07-11-2004, 16:30
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
www.parker.com sells it
you want that robot to do what?
Raider Robotix- www.raiderrobotix.org
Unread 07-11-2004, 19:11
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
Don't forget that if you're planning on using the gussets and other hardware for extruded aluminum they can run up the cost (and weight) quickly also. Also, these fastners are specific to each manufacturer of extruded aluminum and in most cases will not work with another brand.
It's also possible to carefully TIG weld the extrusion together.
As a side note.
Even if you decide not to use extrusion to build your robot it's always nice to have some on hand for prototyping. With the extrusion only bolted together it's very easy to change and modify it as you try different designs and theories. You can also easily move brackets around to try different ideas for drivetrain, for example. Once you have the extrusion frame set to how you want it all you have to do is copy the dimensions to use on your real frame and build it out of whatever material you want.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 07-11-2004, 19:26
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
We used 8020 extrusion for the first 3 years on our robots - and it really helps a team to quickly get a base (chassis) up and tested. And if your team lack the ability or skill to weld - this stuffs the ways to go. But be careful, the T-Nuts (gussets), brackets, and hardware can be twice the cost of the aluminum. Get both regular T-Nuts and the drop-in type. We always find a piece to add on and really need those drop-ins!!
We also chose 8020 since you can fit 1/4" carriage bolts (slightly grinded off for a good fit) inside the 1" extrusion. For a quick prototype, this greatly reduces the cost of the hardware. I also heard you can get 5/16" carriage bolts to fit in the BOSCH 30 series extrusion.
Unread 07-11-2004, 19:41
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
We went to Osh and bought a ton of toilet bolts. They were much cheaper, and fit into the 10/10 8020 series perfectly, and they were long enough that you could use them for whatever you needed and cut them down if necessary
2001-2004: Team 100
2006-Present: Team 254
Unread 07-11-2004, 20:16
The Bosch 30 mm extrusions are designed to accomodate an M8 bolt in the centre hole (which is 0.315"--or as close to 5/16" as one would likely need). The 1" series can take a 1/4-20 bolt in the centre instead.
Unread 07-11-2004, 21:15
REVving up for a new season
FRC #2848 (All-sparks)
also www.itemamerica.com they offer FIRST team discounts
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 08-11-2004, 07:27
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
ITEM is 930's Major Sponsor. We work out of their shop to build our robot. Here is some previous posts about ITEM:
http://www.chiefdelphi.com/forums/showthread.php?t=1775
http://www.chiefdelphi.com/forums/showthread.php?t=1680
Feel free to e-mail loren@item-midwest.com and he could get you any information you need. Mention that you are a FIRST team also.
P.S. He just moved to a new shop so the phone number from the old posts will not work
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 08-11-2004, 08:07
Gdeaver Gdeaver is offline
FRC #1640
Beware of shipping costs. UPS will get you on shipping if the length is over 8 ft. You should be able to find a local supplier in most major metro areas. 8020 maybe great for proto typing and specific mechanism, but the weight will hurt if you try to use it for the whole robot. It also has terrible torsional stiffness. T6061-t6 aluminum in angle, box and tube may be a better choice. Welding aluminum can anneal aluminum and induce stress. High strength steel pop rivets have preformed well on team 104's frame.
Unread 08-11-2004, 14:32
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Very bad memories coming back...
Pipe welder not removing andodized coating on extrusion...
Sound of dying cats coming from weld booth...
Lights diming in the factory!
Seriously I don't recommend this based on the above true incident and it defeats the whole purpose of a modular extrusion frame. But if you do weld the extrusion for the love of your ears, Grind off the coating.
Pete
BTW - I'm not kidding about the sound it ranked up there with the dry ice & aluminum trick.
Unread 08-11-2004, 16:05
aaronbr28040's Avatar
aaronbr28040 aaronbr28040 is offline
AKA: Aaron Bradshaw
#0900 (Team Infinity)
aaronbr28040 is just really niceaaronbr28040 is just really niceaaronbr28040 is just really niceaaronbr28040 is just really nice
Send a message via AIM to aaronbr28040
We used 80/20 extrusion for the past three years obtained from Bertelkamp. They are usually great about getting us our parts fast if we are in a pinch. Extrusion can be combined with lightweight square aluminum tubing to build a very strong/sorta lightweight frame. To cut weight last year I rebuilt the inside platform of our frame with aluminum brackets that I cut to match the extrusion frame and riveted the frame together as we dont have welding capabilities as of yet (I do at home but thats four hours away haha it doesnt help too much). Extrusion is great because they have so many different hinges and joints that can be used. The only problem is that it can get outrageously expensive for some of the hinges and fastening plates. You can talk to some of the distributors and sometimes they will help you out with some discounts.
-Aaron
@North Carolina State University
Team 900
North Carolina School of Science and Mathematics
AIM:aaronbr28040
Unread 09-11-2004, 19:57
laditek laditek is offline
laditek is an unknown quantity at this point
Industrial Profile Systems in Massechusetts. Be careful because the extrusions are slightly different than 8020
Unread 12-01-2005, 21:48
MASherry MASherry is offline
Team Role: Driver
MASherry has a little shameless behaviour in the past
how much does 80/20 weigh?
Carnegie Mellon University Class of 2009!!!
2005- Arizona Regional Champs (Thanks 1492 and 1324)
2005- NYC regional finalists (Thanks 38 and 1660)/ 2005- NYC regional website award
2005- NYC regional J&J Sportsmanship award
2005- National J&J Sportsmanship award
2004- Team Shooter
2004- Crowd Pleaser Award- NYC Regional
2003-7th Place Galileo Divison- Nat's
Mini extruded aluminum Ravi U Technical Discussion 7 17-01-2004 02:12
Blue Man Group FIRST get-together? Gui Cavalcanti Chit-Chat 11 16-09-2003 18:11
Chesapeake Regional - need info! Jferrante Regional Competitions 15 15-03-2003 21:03
Difference in aluminum archiver 2001 1 23-06-2002 23:49
