Go to Post There is a problem getting girls interested in STEM. Swift, immediate action is required. Continuing to stay the course leads to disaster. - Madison [more]
Unread 09-11-2004, 19:57
laditek laditek is offline
laditek is an unknown quantity at this point
Re: where can I get info on extruded aluminum?
Originally Posted by SCYTE16
I really need tech. specs and to find prices for extruded aluminum/plastic/other metals. I'm on the R&D (research and development) team for MORT (team 11) and i really need to find this. plz help. the R&D team just started this year so we have no places with info to just look it up so if you could help i would be very grateful or we will end up like this
Industrial Profile Systems in Massechusetts. Be careful because the extrusions are slightly different than 8020
Unread 12-01-2005, 21:48
MASherry MASherry is offline
Team Role: Driver
MASherry has a little shameless behaviour in the past
how much does 80/20 weigh?
Carnegie Mellon University Class of 2009!!!
2005- Arizona Regional Champs (Thanks 1492 and 1324)
2005- NYC regional finalists (Thanks 38 and 1660)/ 2005- NYC regional website award
2005- NYC regional J&J Sportsmanship award
2005- National J&J Sportsmanship award
2004- Team Shooter
2004- Crowd Pleaser Award- NYC Regional
2003-7th Place Galileo Divison- Nat's
Unread 12-01-2005, 22:45
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
The typical 1010 series that is often used (1" by 1") weighs about 0.5 lbs/ft.
Unread 12-01-2005, 22:51
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
that's the structural material only... if you don't weld it, you're gonna have to add a LOT of weight for the connectors and bolts.
2001-2004: Team 100
2006-Present: Team 254
Unread 12-01-2005, 23:39
Dom Ruggieri's Avatar
Dom Ruggieri Dom Ruggieri is offline
FRC #1676
Dom Ruggieri is an unknown quantity at this point
Item is defenitly the best stuff to go with. there 20 x 20 mil is really light, it's strong.
Unread 13-01-2005, 07:43
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
1" X 1" is .495 lb/ft (part #1010)
1.5" x 1.5" is 1.015 1b/ft (part #1515)
It's listed on pg 36-37 of the catalogue. And yes I use this stuff so much I didn't have to look up the page number.
www.8020.net
Unread 13-01-2005, 14:23
james james is offline
james is an unknown quantity at this point
Cheap material..........dude if you want polycarb half price order it here they deliver http://www.harborsales.net/index.cfm? send a fax with your school state tax # to avoid that cost .For FREE aluminum get in yer car and cruise the indistrial parks and look for a compant that does aerospace fabrication .Or check the yellow pages for METAL FABRICATION they will have sheet stock and xtrusion.Then look for MACHINE shops they do milling and lathe work and mace block stock.When yopu get to know these peeps they will ley U dig in the scrap pile and do shop work for you .
Jim
Mini extruded aluminum Ravi U Technical Discussion 7 17-01-2004 02:12
Blue Man Group FIRST get-together? Gui Cavalcanti Chit-Chat 11 16-09-2003 18:11
Chesapeake Regional - need info! Jferrante Regional Competitions 15 15-03-2003 21:03
Difference in aluminum archiver 2001 1 23-06-2002 23:49
