n00b queston
no one can figure out how to change the channal from 40 to eather 13 or 31 im not sure if this belongs in this forum but if anyone can tell me how to change the channal you would be my hero
Re: n00b queston
I assume this is a question about OCCRA? You should post in the OCCRA forum.
Re: n00b queston
http://innovationfirst.com/FIRSTRobo...nout_Guide.PDF And then once you have made the switch/closed the pins for 'practice'' mode you can play with the channel dipswitches to find the channel you want. |
Re: n00b queston
Check here:
2004 Operator Interface Guide: Page 16, section 14 Section 14 covers all the channel-changing stuff ... any other Operator Interface questions can be answered there, too. Hope this helps! |
Re: n00b queston
thanks we are still having problems but thats becaue our teams just not very good at life
Re: n00b queston
Do this. Get a thin paper clip, or preferably a thin solid wire - do not use stranded wire. Look at the face of the 15 pin competition port on the operator interface so that you can see all the little holes. Bend the paper clip or wire such that you can insert both ends into holes. Insert one end into the top left hole of the connector. Insert the other end into the bottom row, 4th hole from the left. There should be 3 empty holes on left of the bottom row, and then your paper clip/wire inserted in the next one.
See attached pic and use red marked holes. Be very careful to not insert anything in the wrong holes. Also, do not use anything that is too big for the holes, it should go in easy. Click on picture for better view. |
