Go to Post rumors only beget more rumors - JakeGallagher [more]
Unread 10-11-2004, 11:08
CBaoth CBaoth is offline
OMG HAX 4 L1FE NOT JUST CHANUKAH!
None #1489 (Fighting Tuna)
Team Role: Student
CBaoth will become famous soon enough
Send a message via AIM to CBaoth
n00b queston
no one can figure out how to change the channal from 40 to eather 13 or 31 im not sure if this belongs in this forum but if anyone can tell me how to change the channal you would be my hero
Unread 10-11-2004, 11:15
Re: n00b queston
I assume this is a question about OCCRA? You should post in the OCCRA forum.
Unread 10-11-2004, 11:17
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
FRC #0148 (Robowranglers)
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
Re: n00b queston
He may be talking about the IFI controller. To change channels on that you need to look at the Competition Port Pin-Out Guide
http://innovationfirst.com/FIRSTRobo...nout_Guide.PDF
And then once you have made the switch/closed the pins for 'practice'' mode you can play with the channel dipswitches to find the channel you want.
Ricky Quinones
Director of Sales - VEX Robotics
Unread 10-11-2004, 11:18
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Re: n00b queston
Check here:
2004 Operator Interface Guide: Page 16, section 14
Section 14 covers all the channel-changing stuff ... any other Operator Interface questions can be answered there, too.
Hope this helps!
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 10-11-2004, 11:31
Team Role: Student
Re: n00b queston
thanks we are still having problems but thats becaue our teams just not very good at life
Unread 10-11-2004, 12:16
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: n00b queston
Do this. Get a thin paper clip, or preferably a thin solid wire - do not use stranded wire. Look at the face of the 15 pin competition port on the operator interface so that you can see all the little holes. Bend the paper clip or wire such that you can insert both ends into holes. Insert one end into the top left hole of the connector. Insert the other end into the bottom row, 4th hole from the left. There should be 3 empty holes on left of the bottom row, and then your paper clip/wire inserted in the next one.
See attached pic and use red marked holes. Be very careful to not insert anything in the wrong holes. Also, do not use anything that is too big for the holes, it should go in easy.
Click on picture for better view.
