Go to Post I believe everyone should give a modicum of repsect to each person they meet for the first time. After that it is up to them as to whether to give you a reason to increase that respect or detract from it. - Al Skierkiewicz [more]
Unread 09-11-2004, 17:43
Jacko Jacko is offline
Jacko is an unknown quantity at this point
Probably really simple but...
How do I create a curved work plane in inventor? I'm a beginner with this package but I need to create a sketch on a cylindrical surface which I can then use to cut out a profile.
The only way I can think to do this is to create a curved plane, or indeeed curve an existing plane with the sketch on it around a profile?
Does this make sense or am I completely mad!!! I've been trying for ages now but to no avail!
Any help much appreciated.
Cheers
Unread 09-11-2004, 20:20
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Probably really simple but...
I dont have Inventor installed on my computer right now, so I can't tell you step by step how to do it, but if you look at the window on the left side that contains your work planes, you should be able to cycle through them until you reach the one that cuts the cylinder through it's diameter. I think you right click (not sure), but you definitely want to find the option that allows you to offset the work plane. Once you've found it, you can enter the radius, and the work plane will be on the surface of the cylinder.
2001-2004: Team 100
2006-Present: Team 254
Unread 09-11-2004, 22:07
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
You can also sketch a radial (diameter) line on the cross-section of your cylinder, finish the sketch and then select the work plane feature. Click on the end of the line that's on the surface and then move the mouse around until you get a choice for the work plane you want. Then you can sketch on that work plane, making holes and such. I made a quick demo here (800k wmv) ...
I hope it helps.
Unread 10-11-2004, 00:33
rmmlg's Avatar
rmmlg rmmlg is offline
#0900 (Infinity)
rmmlg is on a distinguished road
Another way to do it is extrude a curved line using the shell extrude rather than the full extrude. The shell extrude extrudes work planes in the shape of whatever your 2D shape was, which is quite cool. You will find that anything can be done in CAD many different ways, it is a matter of which you prefer that deteremiens which you use.
Ryan
Team 900 (Infinity)
Unread 10-11-2004, 05:34
Thanks for all of the tips - i'll give them a try tonight when I get home and let you know how i got on.
p.s, Doug G, the link to your demo video isn't working, but I really appreciate the time taken to help me.
Thanks again
Grant
Unread 10-11-2004, 19:38
I've tried all of the suggestions but still cannot get a curved workplane!
in effect I want the surface of the cylinder to be a workplane I can sketch onto, then cut the sketch out of the cylinder to a certain depth.
Any more suggestions or an idiots guide would be great
Cheers
Grant
Unread 10-11-2004, 20:05
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Cheers
Grant
A curved work plane is not a plane. Planes are by definition flat. What you are looking for is a work surface. I'm not sure if Inventor does that, I've never tried. If you explain a little more about what you are trying to do, there might be other ways to go about it.
ChrisH
Christopher H Husmann, PE
"Who is John Galt?"
Unread 10-11-2004, 20:10
Sorry for the confusion. just managed to work it out. I had to create my sketch in 2D on a perpendicular plane to the cylinder then emboss my sketch to a depth of 1mm into the cylinder by opting to "wrap" it to the surface of the cylinder. Long way for a shortcut!!!
Cheers to everyone who helped me out.
Grant
help with simple project erikh98 Technical Discussion 8 27-08-2004 11:24
A Simple note about life dddriveman Chit-Chat 14 13-05-2004 20:33
White Paper Discuss: Simple strategy/couter-strategy sheet CD47-Bot Extra Discussion 2 06-04-2004 22:37
Simple things you can do to make your bot/team perform better KenWittlief General Forum 21 01-04-2004 15:11
Simple Autonomous Mode Example deltacoder1020 Programming 5 08-03-2004 20:22
