Go to Post The point of FRC (in my opinions) is to teach the kids that might have no skills, new skills. - dirtbikerxz [more]
Unread 11-11-2004, 16:11
jdong jdong is offline
Linux Nerd
AKA: John D
#0245 (Adam-Bots)
jdong will become famous soon enoughjdong will become famous soon enough
Adambots-Live Linux Makefile -- version 0.1 RELEASE
https://sourceforge.net/project/show...ease_id=281942
Notes:
This is a makefile that can be used as a Linux-replacement for MPLAB.
--Features--
Parses any MPLAB project containing folder (i.e. default code) and finds all the .c / .h files to compile
Uses WINE in conjunction with mcc18.
--Requirements--
It assumes that there's a /opt/mcc18 folder containing mcc18 in the SAME STRUCTURE as the Windows C:\mcc18.
It requires WINE. I've tested with 20040615 and 20040716.
Indent and Fortune are optional, but recommended.
The ifi-pictools or ifi-picloader packages are required to load the code.
--Operation--
Copy this file to the folder containing your code. Issue the following commands to get started:
gunzip [name_of_makefile]
mv [name_of_makefile] Makefile
mkdir .conf .deps
touch .conf/dummy
touch .deps/dummy
At this point, edit the makefile to modify its variables. Excuse the user-unfriendliness... It'll be improved / autodetected at a later version
Type (make target) to make a target. Possible targets:
(nothing) -- Generates FrcCode.hex file by building everything
file.o -- Compiles file.o from file.c
clean -- Removes compiled files, forces rebuild next time
prettycode -- Indents/reformats code.
load -- Use picloader to load the Hexfile to /dev/ttyS0
read -- Read robot output from /dev/ttyS1 (requires picreader)
Please test & comment.
File bugs at : https://sourceforge.net/tracker/?gro...94&atid=683416
File improvements / patches at: https://sourceforge.net/tracker/?gro...94&atid=683418
Need help? https://sourceforge.net/tracker/?gro...94&atid=683417
John Dong
Co-Captain, Webmaster / Programmer
Team 245 -- Rochester Adams Robotics
Unread 11-11-2004, 16:14
Linux Nerd
AKA: John D
#0245 (Adam-Bots)
Re: Adambots-Live Linux Makefile -- version 0.1 RELEASE
You can track the live CVS developments at http://cvs.sourceforge.net/viewcvs.p.../code/Makefile
0.1 was CVS revision 1.10; there's always a few hours of ViewCVS lag with sourceforge
John Dong
Unread 12-11-2004, 11:29
Michael Auchter Michael Auchter is offline
#0068 (Truck Town Thunder)
Michael Auchter is on a distinguished road
I'll be sure to check this out when I get home today. I would love to get away from my dependence upon windows for programming.
By the way, I was the kid from Team 61 talking to you at Berkley.
Unread 12-11-2004, 19:12
Linux Nerd
AKA: John D
#0245 (Adam-Bots)
Note: Makefile in CVS now expects /usr/bin/picloader_console frontend (percentage display)
Get your copy at http://sourceforge.net/project/showf...ease_id=281999
The console frontend still calls the ifi-pictools >=0.4.97 (0.5 beta 1) in the background. You still need the ifi-pictools package!!
John Dong
Unread 17-11-2004, 18:41
Linux Nerd
AKA: John D
#0245 (Adam-Bots)
Hmm, my Ubuntu Warty system used mawk, under which my awk expression worked. Under Ubuntu-development Hoary branch and apparently on some other distros, the makefile didn't work because it replaced all c's with .o! oops!
Corrected in release 0.1.1
https://sourceforge.net/project/show...ease_id=283489
John Dong
Fav. Beatles Song MattK Chit-Chat 17 04-12-2002 17:18
RoboIDE 0.1 (Linux PBASIC IDE) rbayer Programming 1 29-11-2002 14:48
