Re: which is better aluminum or steel????
I suggest that you come up with a list of attributes that you think are important for the frame of a robot. Then you can compare each one on an attribute by attribute basis.
Strength and cost are two possible attributes, but there are many more that you can compare. There isn't a correct answer for your question. That's why you need to break it down into smaller steps. |
| Welding stainless steel to mild steel... can it be done? | Travis Covington | Technical Discussion | 3 | 27-01-2004 19:11 |
| Mini extruded aluminum | Ravi U | Technical Discussion | 7 | 17-01-2004 02:12 |
| Difference in aluminum | archiver | 2001 | 1 | 23-06-2002 23:49 |
| Let's get some aluminum extrusions | archiver | 1999 | 3 | 23-06-2002 23:12 |
| Legality of steel tubing. | newy | Rules/Strategy | 3 | 01-02-2002 09:16 |
