Go to Post Whenever we loose a committed member of FRC, our entire country pays the price. - daniel_dsouza [more]
Unread 12-11-2004, 13:34
indieFan indieFan is offline
RoboDox and LVHS - Missing you!
FRC #5941
indieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond repute
Servo Rotation
My group is planning on using a servo identical to the one in the KoP, along with a Hitec Laser 6 radio control system (for model airplanes). We need the angle of rotation to be greater than 60 degrees. Is there a simple way of doing this?
Thanks,
indieFan
Unread 12-11-2004, 13:45
Re: Servo Rotation
The angle of rotation of the kit servos is about 300 degrees.
Unread 12-11-2004, 13:53
FRC #5941
Re: Servo Rotation
Ok, but how do you get the full 300 degrees of rotation using a hobby shop remote control system? Right now I'm only seeing 60 and adjusting the trims only made the rotation smaller.
indieFan
Unread 12-11-2004, 17:20
Re: Servo Rotation
Indie,
As I remember, the servo is about 60 degrees. You need to couple another gear or gearset to get the angle you require. Mechanical linkage works OK too!
Unread 13-11-2004, 01:17
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Re: Servo Rotation
Or you could take a file and file off the nub that stops the servo and make it turn 360, basicly making it a motor. Just pop off the top and there is a small tab that conects to the pot I believe is in there and makes it stop. I dont have my modified ones near by to say forsure exactly what to do. But it goes something like that.
-Mike
Unread 13-11-2004, 08:24
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Re: Servo Rotation
Keep in mind that the force exerted by the servo drops off rapidly when the 1/2 angle is greater than 30 deg.
This message is hidden because Jack Jones is on your ignore list.
Unread 13-11-2004, 13:41
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Re: Servo Rotation
You also might want to replace the pot with a resistor (preferably one that matches the mean resistance of the pot) to prevent drift. However, this will give you a motor with a built-in speed controller, not a servo which can go to a specific position.
Zan Hecht
Servo MASherry General Forum 6 04-10-2004 22:46
Interrupts and rotation sensors kor Programming 3 12-02-2004 11:05
Tracking beacon without servo Paul Marshall Technical Discussion 17 10-02-2004 20:58
servo problems lpramo55 Programming 5 20-01-2004 22:23
