Go to Post So, if you feel your team is at a disadvantage, or the playing field isn't level.... Do something about it. - AdamHeard [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 12-11-2004, 13:36
SCYTE16's Avatar
SCYTE16 SCYTE16 is offline
AKA: Gordon Tennyck
#0011 (MORT)
Team Role: Student
SCYTE16 is on a distinguished road
Question which is better aluminum or steel????
which is better aluminum or steel for making an outside of a robot????
Unread 12-11-2004, 13:46
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Re: which is better aluminum or steel????
Not sure what you mean by "angled outside"? We have used aluminum for our frames since we started building robots. Yes It bends every now and then, infact we bent team 25's steel diamond plate in 2003.
The bends we get are nothing a hammer and fire can't fix.
Here is a picture of 2004 frame:
http://www.tigertrons.com/Pictures/2...n/100_0535.JPG
Edit:
We use 1/8'' wall thickness by 1.25'' angle aluminum.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 12-11-2004, 13:49
I suggest that you come up with a list of attributes that you think are important for the frame of a robot. Then you can compare each one on an attribute by attribute basis.
Strength and cost are two possible attributes, but there are many more that you can compare.
There isn't a correct answer for your question. That's why you need to break it down into smaller steps.
Unread 12-11-2004, 18:04
NotaNerd's Avatar
NotaNerd NotaNerd is offline
I am a physics god
AKA: Alex
FRC #1418 (Vae Victus)
NotaNerd will become famous soon enough
Not only is is just a factor of strength and cost, but also weight. You need to figure out if any parts of your robot will undergo tension, compression, or excess stress. Then, begin assigning materials to sections. To other way is to use what you have where you can use it
Unread 12-11-2004, 18:31
The Cyborg's Avatar
The Cyborg The Cyborg is offline
That Awkward One
AKA: Mary Soltis
FRC #0051 (Wings of Fire)
The Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant future
Our team mostly uses aluminum on our robots, but for things that fall under great stress, like hooks, latches, and wheels, we use steel.
Aluminum is durable, lightweight material that can be easily cut, drilled into, and be bended into certain angles and shapes; not to mention it is inexpensive and abundant. But aluminum can also break under high stress and can also wear down more easily than steel.
Steel in incredibly strong, and can not bend as easily as aluminum. But, however, steel can not be cut or drilled as easily as aluminum. Steel is also heavy, and can be good for balancing your robot, but don't use too much! Steel is also expensive, making a 4X4 sheet cost about $40! The major factor, however, is that steel can rust, and can eventually break down after a long while; so if you are planning to use a robot for a long time, I suggest using as much aluminum as possible.
Unread 12-11-2004, 19:14
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
there is only one thing i can say...
Aluminum is way cheaper... Steel is way stronger and heavier. Most of the teams in FIRST uses Aluminum on their robot. this past year my team has used Steel gears for the transmission. but my suggestion would be use harden aluminum for gears and aluminum to build your robot. Aluminum gives you the option to play with weights. good luck.
Unread 12-11-2004, 21:15
Nope. Steel angle is about half the price of aluminum angle.
Unread 12-11-2004, 21:42
AKA: Ari
Joe's right... i was debating about it... i should have researched before i posted... sorry...
Unread 12-11-2004, 22:08
George1902's Avatar
George1902 George1902 is offline
It's a SPAM thing...
AKA: George1083; George180
FRC #0180 (SPAM)
George1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond repute
There was some really good discussion in this thread.
Enjoy! =-]
George
"Darkness cannot drive out darkness; only light can do that. Hate cannot drive out hate; only love can do that."
-- Martin Luther King, Jr.
Unread 12-11-2004, 22:41
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
steel is cheaper, stronger, and comes in a variatiy of shapes sizes hardnesses and flavors
Unread 12-11-2004, 23:31
Bill Gold Bill Gold is offline
Retired -- 2006
Bill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond repute
It's also denser than aluminum. Aluminum also comes in "a variety of shapes, sizes, and hardnesses,” so that shouldn’t be any reason to choose steel over aluminum as your material of choice.
If you’re not into using something like 80/20 (or other comparable “erector set” materials) I would suggest a basic frame be made out of something like 1” x 1” x 0.125” thick or 1” x 2” x 0.125” thick aluminum tubing. Portions of the frame that you would assume wouldn’t be exposed to much stress can probably be made out of .0625” thick aluminum tubing. You can decrease the weight of your frame and other components by drilling lightening holes in the tubing, as well.
A good example would be the robot I worked on last year.
Picture 1
Picture 2
Picture 3
The lower and upper arms were 3" x 3" x 0.125" aluminum tubing and the gripper portions were 1" x1" x 0.125" aluminum tubing. We saved a lot of weight with those holes.
I would second George's suggestion that you read the thread he has linked in his post above, if you haven't already. It’s always good to see your posts, George. It feels like such a long time since the Tigerbolt days. I hope everything’s going well for you, man.
-Bill
Unread 13-11-2004, 09:17
Bcahn836's Avatar
Bcahn836 Bcahn836 is offline
Iraq is fun.
AKA: Brad Cahn
no team (Robobees 836)
Bcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond repute
Send a message via AIM to Bcahn836 Send a message via Yahoo to Bcahn836
Aluminum is also easier to work with, i know not many machines in our shop can handle steel. Plus as mentioned before it is much lighter. We have used aluminum on all three of our robots and we have had no problems.
Unread 13-11-2004, 10:08
N7UJJ N7UJJ is offline
Teacher
AKA: Allan Cameron
FRC #5465 (BinaryBots)
N7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond repute
Answer: None of the above
Team 842 has used the fiberglass from Creative Pultrusions for several years. http://www.pultrude.com/
It's the material of choice for us. Several reasons:
5 times stronger than steel for its weight.
Lightweight
It can be worked with hand tools - drill, hacksaw, screwdriver. Field repairs could be made with a Swiss Army knife that has that little saw!
If anything breaks, we can fix it in the pit wihout welding, machine shop, etc.
Electromagneticly transparent (No radio wave problems)
Won't corrode
You can buy it in all kinds of forms: I beams, angle beams, round tubes, sqare tubes, etc.
Its fantastic stuff.
And .. no they don't sponsor us -- we tried, though. They should!
Unread 13-11-2004, 10:26
[527]phil's Avatar
[527]phil [527]phil is offline
Alumni
AKA: Phil
FRC #0527 (red dragons)
[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light
Send a message via AIM to [527]phil
yeah aluminum is definatly my metal of choice, i work in a machine shop and steel is alot harder to machine than aluminum, it's also usually heavier. hmmm that fiberglass sounds like it might be a good material, i'll have to check it out for my team.
Whats the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons, civil engineers build targets
Unread 13-11-2004, 11:15
ZACH P. ZACH P. is offline
Insert Custom User Title
#0321 (Robolancers)
ZACH P. is on a distinguished road
Send a message via AIM to ZACH P.
Say, do you have any picture of your robot available?
pi is exactly 3
IM me at: zmstr265
Welding stainless steel to mild steel... can it be done? Travis Covington Technical Discussion 3 27-01-2004 19:11
Mini extruded aluminum Ravi U Technical Discussion 7 17-01-2004 02:12
Difference in aluminum archiver 2001 1 23-06-2002 23:49
Let's get some aluminum extrusions archiver 1999 3 23-06-2002 23:12
Legality of steel tubing. newy Rules/Strategy 3 01-02-2002 09:16
