Go to Post The solution to that "problem" is obvious: practice driving. - Alan Anderson [more]
Unread 27-01-2004, 23:37
Nero's Avatar
Nero Nero is offline
#1155 (SciBorgs)
Nero is an unknown quantity at this point
Send a message via AIM to Nero
Re: 341 Needs Animation Help!
80/20 has a CD that has a lot of Autocad representations of their parts. Call them and ask them for it. For aluminum extrusions, i would just recommend going to Firstcadlibrary, downloading the 1x1, taking a section of it to make a spline, then just extruding that spline to whatever length you want.
Enjoy!
Oh yeah! I'm born on National Techie Day!!!
Unread 27-01-2004, 23:39
Lev's Avatar
Lev Lev is offline
#0116 (Epsilon Delta)
Lev will become famous soon enough
I personally see no problem with use of FirstCAD Library. Its not like any of the models posted there are amazingly complex, or spectacular visually. You have to do quite a bit of work to make them look right after you download them, like filleting the sharp edges, simplifying excess detail, and mapping with good textures. Modeling any of those would not benefit my 3d skills, since most of them are pretty trivial, and there is no challenge in doing them - just time effort.
There is a big difference in downloading a car model from 3dcafe and downloading a metal extrusion from FirstCAD library, because in the first case you are downloading it because you dont know how to make the model yourself, but in the second case you download it just to save time on grunt work. It takes skill and creativity to model a car. It takes simple ability to follow a blueprint to model a robot part in Inventor. I would download the FirstCAD Library model so that i have more time for tasks i find challenging - like complex model, realistic lighting, and detailed textures.
About the rules. That line in the consent form was always there. Yet autodesk did offer in past years kit parts modeled in inventor for download for use in animations. I dont see how using FirstCAD Library is any different, even more so since more people know about FirstCAD Library than about the files Autodesk gave away - its a resource available for everyone.
So here is the bottomline in my view - if you think that you could learn something by doing the model yourself, you probably should. Otherwise, i dont see much point in doing gruntwork models such as kit parts.
Unread 27-01-2004, 23:43
Matt Hallock Matt Hallock is offline
#1188 (Oaktown Crewz)
Matt Hallock is on a distinguished road
Send a message via ICQ to Matt Hallock Send a message via AIM to Matt Hallock Send a message via Yahoo to Matt Hallock
Originally Posted by OneAngryDaisy
We used to have an animation team two years ago, but last year our focus shifted on our robot.. thus, we had no animation team, but this year three freshmen have stepped up and shown an interest in learning this.. I really don't see the harm in letting them learn how to use the program, its actually pretty awesome to see animation be reestablished.. It's just like a new rookie team using FIRST's gearboxes to learn how the game works..
There is a difference between letting people learn the program, which is what I'm trying to say here, and outrightly taking someone elses work and putting it in an animation.
KCY, yes, there is an enormous difference between the scanline and the Brazil renderer, but I'm talking about Brazil vs. Mental Ray, which comes with MAX 6. Turn off the GI and it looks completely different, personally I feel the GI makes objects look like play-dough, but that's just my opinion.
Lead Animator for Donder-Kimball High School, team #1188.
Unread 27-01-2004, 23:47
Lev's Avatar
Lev Lev is offline
yeah - in many cases specular highlights are missing. It is most noticeable when using max's lighttracer. Cranking up specular values and adding some light other than skylight usually fixes that.
Unread 27-01-2004, 23:51
Default, like scanline.
Play-dough.
My lighting, textures, etc, no GI.
There is a big difference I feel.
Unread 27-01-2004, 23:54
Lev's Avatar
Lev Lev is offline
Wow, the last one is no GI? the shadow patterns over the textures match almost perfectly with the "play-dough" render.
Unread 28-01-2004, 15:12
When you turn on secondary, or indirect lighting, you'll get the same shadowing especially when you turn on bounces more than one.
After sleeping on it, I suppose anything that is given to you by FIRST or Autodesk should be usable, like the extrusion CAD files, I agree it will make things less grunt work and more time to actually work.
Unread 28-01-2004, 16:31
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
What's to stop people from saying that about a car or something? "Well, looks like I can't make this, so I'll just take it and put it in the animation." It screws over people who actually did all the work, like the teams agreed to when they sent in their consent forms.
There is a BIG difference between using a car that someone else made and using a small part like a motor. The FirstCAD Library is there to use as a resource, and there's absolutely NOTHING wrong with using it. Ed Sparks devotes his time and energy so that we can use what he has made, so why wouldn't you use it? I guess if you want to spend weeks making intricate small parts that came with the kit of parts, go ahead, but I know I'd much rather focus on getting my message across in my animation.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 14-11-2004, 18:14
Paranormalfreak's Avatar
Paranormalfreak Paranormalfreak is offline
- Lana
AKA: Lana McAlinn
#0341 (Miss Daisy)
Team Role: Animator
Paranormalfreak has a little shameless behaviour in the past
Send a message via AIM to Paranormalfreak Send a message via MSN to Paranormalfreak Send a message via Yahoo to Paranormalfreak
It's been awhile since I've checked on this thread--And I believe that some of the things said in the contents of this thread are out of line. I understand that the animation had to have been our own work, through and through. IT WAS.
We were just trying to find reference, and in the end--I dont think we needed it.
L a n a
Sing me a SONG! Biggs717 Chit-Chat 78 09-05-2003 07:59
Yeah, remember that whole BIOS thing? I never did like it.... DanL Chit-Chat 18 22-03-2003 18:37
yeah right. soezgg General Forum 38 12-02-2003 10:37
Yeah... about these boxes.... Hubicki General Forum 11 08-01-2003 15:12
CHAT OF THE CENTURY! CLICK HERE! archiver 2000 4 23-06-2002 22:18
