Go to Post You can lead a horse to water but you can't make it drink. Our job is to make the horse thirsty. - Andrew Schreiber [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 16-11-2004, 18:21
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
XP Services
I'm wondering how I can unregister services from XP. For instance, I had Darwin Streaming Server installed at one point, but then I got rid of it. Unfortunately, it didn't have an installer, so the service is still in the "Services" list.
Anyone have a freeware program to get rid of this sort of thing? I'm not going to try to directly edit the registry (unless you have very specific directions...)
Not sure if you would want this in here or somewhere else. Sorry if you don't like it.
Unread 16-11-2004, 18:41
Alexander McGee's Avatar
Alexander McGee Alexander McGee is offline
Hoonigan
AKA: Alexander S. McGee
no team (no team)
Alexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond repute
Send a message via AIM to Alexander McGee Send a message via Yahoo to Alexander McGee
Re: XP Services
I use a program called Scotty Win Patrol
http://www.winpatrol.com/winpatrol.html
It's a great program for freeing up unwanted stuff like that, without using msconfig or anything like that.
Try it out! It's free!
-Alexander S. McGee
Intellectual Property Attorney, Mechanical Engineer, Gear-head
Unread 16-11-2004, 20:05
MaxPowerX MaxPowerX is offline
MaxPowerX is on a distinguished road
Re: XP Services
got to blkviper.com or something of that sort. He has a pdf explaining which services should or shouldn't be disabled.
Good luck
Unread 17-11-2004, 06:59
Programming User
Re: XP Services
Thanks guys.
What I'm really looking for is something to completely remove them from the list, not just disable them. I'm not sure if such a thing even exists, but it's worth a try.
Unread 17-11-2004, 09:40
Suneet Suneet is offline
Physicist-In-Training
None #0599 (RoboDox)
Suneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to behold
Send a message via ICQ to Suneet Send a message via AIM to Suneet
Re: XP Services
If you know the name of the .dll, then try opening a command line and use the command "regsvr32 your.dll /u" . I think that unregisters a .dll from the services.
Unread 17-11-2004, 11:39
Hoonigan
no team (no team)
Re: XP Services
Actually, scotty will allow you to do that. Just use delete instead of the disable button. I've done it millions of times.
If you still can't figure it out, use the "run" command and run "msconfig" without the "". Then, go over to the startup tab, and find the things you dont want and delete them. That works too.
-Alexander S. McGee
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
Anyone else having trouble with Yahoo mail services? Elgin Clock IT / Communications 12 20-03-2004 16:59
2004 FIRST Video Services! Joe Matt General Forum 7 24-02-2004 09:58
Change to FIRST logo.... Clark Gilbert General Forum 2 15-12-2002 20:12
Teams together off the field archiver 2001 24 24-06-2002 02:19
