XP Services
I'm wondering how I can unregister services from XP. For instance, I had Darwin Streaming Server installed at one point, but then I got rid of it. Unfortunately, it didn't have an installer, so the service is still in the "Services" list.
Anyone have a freeware program to get rid of this sort of thing? I'm not going to try to directly edit the registry (unless you have very specific directions...) Not sure if you would want this in here or somewhere else. Sorry if you don't like it. |
Re: XP Services
I use a program called Scotty Win Patrol
http://www.winpatrol.com/winpatrol.html It's a great program for freeing up unwanted stuff like that, without using msconfig or anything like that. Try it out! It's free! |
Re: XP Services
got to blkviper.com or something of that sort. He has a pdf explaining which services should or shouldn't be disabled.
Good luck |
Re: XP Services
Thanks guys.
What I'm really looking for is something to completely remove them from the list, not just disable them. I'm not sure if such a thing even exists, but it's worth a try. ![]() |
Re: XP Services
If you know the name of the .dll, then try opening a command line and use the command "regsvr32 your.dll /u" . I think that unregisters a .dll from the services.
Re: XP Services
If you still can't figure it out, use the "run" command and run "msconfig" without the "". Then, go over to the startup tab, and find the things you dont want and delete them. That works too. |
| What is your most prefered programming language? | Hailfire | Programming | 156 | 19-01-2005 21:42 |
| Anyone else having trouble with Yahoo mail services? | Elgin Clock | IT / Communications | 12 | 20-03-2004 16:59 |
| 2004 FIRST Video Services! | Joe Matt | General Forum | 7 | 24-02-2004 09:58 |
| Change to FIRST logo.... | Clark Gilbert | General Forum | 2 | 15-12-2002 20:12 |
| Teams together off the field | archiver | 2001 | 24 | 24-06-2002 02:19 |
