Go to Post May the road accelerate in the Z direction, and the wind always be from -Y (modernized Irish blessing). - KenWittlief [more]
Unread 11-11-2004, 22:53
incognito_NICK's Avatar
incognito_NICK incognito_NICK is offline
hidden in the corner
AKA: Nick Ferreira
#0179 (Children of the swamp (swampthing))
incognito_NICK will become famous soon enough
Send a message via ICQ to incognito_NICK Send a message via AIM to incognito_NICK
help with programing banner senor.
how do i create a working print statement to see if my banner senors are working? i really have no idea.
(email me if you want to see the code: metalcalibur@gmail.com)
Unread 11-11-2004, 23:14
AKA: Dr. Brooks
no team (WRRF)
First, check that it is working from the indicator lights on the sensor.
After you have done that, and have it wired to a digital input, you have to write code that remembers the prior value and runs the printf() call when it sees the value change. Replace Process_Data_From_Master_uP with the one below, and the two variable declarations:
int old_rc_dig_in10, new_rc_dig_in10;
void Process_Data_From_Master_uP(void) {
Getdata(&rxdata);
if((new_rc_dig_in10 = ((int)rc_dig_in10)) != old_rc_dig_in10) {
printf("rc_dig_in10 = %d\", new_rc_dig_in10);
old_rc_dig_in10 = new_rc_dig_in10;
Putdata(&txdata);
In the case above, the sensor is wired to digital input 10.
You can generalize this to all of the digital input, RC and OI,
and produce a debugging program for your switches. A
similar thing can be done with analog sensors, but you will
want to add a "sensitivity window" to keep "noise changes"
from causing printf()s galore.
If you want to print the sensor value directly, you must cast
it to an int. printf("%d\n", (int)rc_dig_in10)
Eugene
Unread 17-11-2004, 06:51
AKA: Nick Ferreira
Re: help with programing banner senor.
thanks for the help. we needed it.
Segway Banner Ad JohnBoucher Dean Kamen's Inventions 3 09-10-2004 14:19
Banner Sensor Programming Problem 2Crisis Programming 4 24-02-2004 13:40
Banner Sensors ESchneider Control System 8 18-02-2004 12:17
banner sensor positioning and times bob1million Programming 4 16-02-2004 13:40
Is there a size regulation for the pit area if we wanted to put up a banner Ragin_Kage General Forum 6 14-03-2002 15:33
