Go to Post Building a robot is one thing - but the fun I have had with my mentors, parents, and other students on team outings is something I cherish. - SuperJake [more]
Unread 15-11-2004, 16:18
SpaceOsc's Avatar
SpaceOsc SpaceOsc is offline
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
SpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant future
Send a message via AIM to SpaceOsc Send a message via Yahoo to SpaceOsc
Calibrating Victors
Originally Posted by Denman
sorry, i said i would be back in half an hour... then someone managed to make the battery catch fire.... (the wire we are using for our forklift is metallic, and it fell off onto the battery terminals...........) luckily it didn't damage anything.
Al, i had a look, and yes, the speed controllers are wired up into the motors So i suppose i just remove them and wire the speed controllers directly to the motors.
And thus it is nothing to do with "putting a back current on the speed controlllers (ref our mentor ))
That Lil Stunt happend to my Buddy John, during competetions he was tired and almost falling asleep and pulled a metallic Winch Cable we installed and the wire bridged both terminals of our battery, a powerful flash occured and he was thrown away(not by the power but by fear lol) and the wire turned chard black and split in the mid point been the contact point. no smoke no fire, just a broken winch cable (Heres a tip about metallic wires, u can crimp them back together if u do it right)
as for your problem
from what i can tell on this thread this is your setup
Battery = Breaker = Fuse Box = 40/30 amp Fuse = Victor 88* = Spike = Motor
which is Incorrect, when running a motor (drill, CIMs, FP .. etc) you can only have Victors running and taking the load of your motors.
the Correct Circuit would look like
Battery = Breaker = Fuse Box = 40/30 Amp Fuse = Victor 88* = Motor
Spikes are only to be used on Things that require only on and off commands such as your Compressor , Silenoids, and some of the lower end Motors that dont require variable speed.
That Setup Is non Negotiable, despite what may feel to be a better setup, or more efficient Short Cuts , such is Using Higher Gauge wires to lower resistance, or using the incorrect fuses to allow more power to flow in, are unstable practices that may back fire at unpredictable times, FIRST knows whats it is doing and has its guide lines reflecting functionality and safety all in one. If your going to be showing Rookies how to setup electronics you must make sure they learn it the FIRST way first, then they can think outside of the box all they like while following the rules.
as for other aspects that of victor that have nothing to do with anythign else on the board that u might wanna consider for your Solution
Brake/ Coast - lil Jumper on the Victor (If im wrong plz correct me, i know lil about the workings of this function)
I believe the Brake Function Causes the Victor to Draw Power to counter the Motors Movement and stall it. perhaps you may wanna try and see if switching the jumper changes anything, they are standard computer jumpers so if for some reason you have lost yours, any old computers mother board and some old ISA cards can povide you with the jumper.
Calibration - The lil Depression Switch you can only get to with a needle
You mentioned something about only going one direction?
The Victors Require Calibration to mesh up with the calibration on your joysticks. The OI has a range of -126 to 126 (from what i remember) for the joysticks, -126 being fastest backward speed and 126 being Fastest Forward Speed and ZERO (the Mid point Number) would be your neutral (Using the dashboard program from IFI can help u calibrate in a snap)
anyways your joy stick could be off center yet your victor thinks it is centered so this off set with provoke the victor to run oppsite direction of the offset, if the offset is incredibly bad your ranges could be Fastest Foward Speed 126 and your neautral -126 (-126 becoming your new Zero)... that means that since there nothing under -126 then you simply cant go backward because that would be out of range. that could explain your one direction problem. Ive had times when Victors All sudden Need to be Recalibrate for seemingly no reason. it could be a short causing the victor to reset to its original position which may Completely be off with your controls (Calibrate Both together!!!!) For instructions on Recalibrating see the Victor Manual. it tends to be a two person operation. so get someone who will not move the controls while this occurs and move them when they Have to.
last Recommendations
-Get a Compressed Air Can and clean all your parts from metal and other debris.
-Check all your crimps and solders, any bad job on any of these can cause power loss and heavy resistance even if its just one crimp and even if its just one cable.
My Roll Of Pennys
-Osc-
2014-2017: Team 4501 Coach/Lead Mentor
2002-2011: Team 702, Mentor
2001-2002: Team 702 Captain
Unread 15-11-2004, 16:44
Billfred's Avatar
Billfred Billfred is offline
Re: Odd How a Thread About Spikes would be all about Victors
I'll throw in one thing on brake and coast...
Basically, when you turn a motor with your hands (assuming no worm gears or other stuff gets in the way), you're creating electricity. What the brake function does is create a short circuit for the motor. Thus when you turn the motor, the electricity it generates is used to counter your rotation.
If you want a really simple example, get a Lego motor and some wire. If you put the wire on right, that axle should hold like the Lake Murray Dam.
(memo to self: don't use terms that only (counts...1293, 1336, 1398, that rookie team...) four teams will understand.)
Unread 15-11-2004, 20:05
Jeff_Rice's Avatar
Jeff_Rice Jeff_Rice is offline
ElementisRegamusProelium
#1359
Jeff_Rice will become famous soon enoughJeff_Rice will become famous soon enough
Re: Spikes
In popular science they write about a conducting plastic, and they talk about using it in this manner for car brakes. (They called them "PlastiBrakes")
Just in case you want to read a further description of this phenomenon.
"He said my name is Private Andrew Malone
If you're reading this then I didn't make it home
But for every dream that's shattered another one comes true
This car was once a dream of mine now it belongs to you
And though you may take her and make her your own
You'll always be riding with Private Malone" David Ball, "Private Malone"
Unread 15-11-2004, 23:45
occra 23.
AKA: ryo
None #1481
use a new "old" lego motor. the "new" motors are geared down. and old "old" one like mine... like 10yrs old loses its efficiency so it wont work too well
[edit]nvm. it doesnt matter if its geared or not. just dont backdrive it enuf to damage it.[/edit]
Unread 16-11-2004, 07:51
Re: Spikes
Osc,
Nice job on the explanation but let me add a few things.
On the wire guage, FIRST rules set wire minimum size. You can go to larger wire but at the sacrifice of weight. As long as the proper fuses and breakers are in place, there is no likelihood of fire.
As to burning wires when they fall across the battery terminals, you have a great example of the dangerous condition that exists with a battery capable of more than 400 amps at full charge. Any metallic object that contact both terminals of the battery (or anything the battery is connected to) will cause 400 amps of current to flow. This could be a ring, watch band or necklace where bodily harm is the result. Fire is also a very good possibility and we don't want fires anywhere FIRST robots or people live. Depending on the device causing the short, (a wrench for example) the metal can weld itself to the battery permanently, and the result could be an explosion. Therefore, (I will say this over and over) all battery terminals must be wrapped in tape or other insulating material AT ALL TIMES! There is no exception to this rule, ever. Secondly, all terminals that are connected to the battery must be insulated as well. i.e. main breaker, breaker panels, all connectors.
On the subject of coast vs. brake. The speed controller is capable of supplying a short across the motor, simply by turning on two sets of FETs. This produces braking in the motor through a condition known as "back EMF". It is not a firm brake but does a nice job slowing the robot down to help it become a more stable platform. This method is much more preferable than leaving the braking pins in on the Bosch transmissions.
Final word, insulate all terminal connected to battery at all times, no exceptions. This includes chargers.
Live safe, work safe always wear safety glasses.
BTW, if anyone has an question that they feel is embarassing to ask in public, please PM me. I want you to get the right answer no matter what.
Unread 16-11-2004, 08:47
Electrical Engineer
Rookie Year: 1995
-Osc-
Osc,
Actually, the PWM output is:
0 = Full Reverse
1-126 = variable reverse (1 is fastest)
127 = no movement
128-253 = variable forward (253 is fastest)
254 = Full Forward
255 = Do not use
Secondly (and please understand that there are many ways to skin a cat), I've been electrical mentor on 177 since 1995 and, since the IFI controls came out, I have never had to calibrate a Victor. We check the trim on the joystick trimpots before every match and, if necessary, retrim to "zero" (PWM = 127 when your hands are off the joystick). After trimming, we use electrical tape to "clamp" the trim and keep the operators from accidentally hitting the trim wheel during a match.
Works like a charm...
Regards,
Mike Betts
As easy as 355/113...
Unread 16-11-2004, 10:39
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
Mike - It was always my understanding (please correct me if I'm wrong) that the calibration was to allow for variations in the actual range of the joystick. If the upper value of the internal pot is 90 ohms (10% tolerance on 100k...may differ in practice), the highest value that your speed controller would ever see would be 228. That puts a clamp on the fastest you can ever drive that speed controller, and in return, motor if you were to not calibrate.
What the calibration does, as I understand it, is scale the way the inputs are converted to outputs. In the above example, after calibration, a value of 228 as an input will cause the speed controller to drive full forward, and a value of 114 would be the neutral value.
Can somebody either confirm this or smack me upside the head?
Unread 16-11-2004, 10:41
Re: Spikes
Mike,
Thanks on the PWM values, I knew there was something I was forgetting!
We calibrate speed controllers regularly. We never trust that they are delivered in the mode we need or that they will stay where they are told. As a matter of fact, our software team has written specific calibrate functions which we use to insure that everything on the robot is correct before going onto the playing field.
Dave, take a smack up side the head out of petty cash. Now seriously, I was under the same impression, the calibrate procedure stores both max and min values in addition to the rest position and scales the input accordingly. That makes the joystick match absolute values. Full up is 255 whether from the joystick or auto software. Analog is so ambiguous, but I like it.
Unread 16-11-2004, 13:59
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Re: Spikes
I was dubious when you guys started talking about the Victors calibrating the high and low ends. I thought it only re-centered the neutral point. (Yeah, I know that, with some reflection, that doesn't make a lot of sense, but, ... what can I say? ) Anyway, I found this in the Victor User Manual:
Calibration Instructions:
The Victor 883 is pre-calibrated to values compatible with the FIRST control system. No calibration is required for normal operation.
NOTE: While in calibration mode, the Victor 883 will record the maximum PWM value detected as ‘full forward’, the minimum PWM value as ‘full reverse’, and ‘neutral’ will be the PWM value recorded at the release
of the Cal button.
(And it then goes on to give directions for calibration.)
So my new flip-flop position is that you may indeed want to calibrate your Victors to match your joysticks. However my weasel words to the wise are that calibrating the Victors to untrimmed joysticks could have deleterious effects on your autonomous code!
Let's say your joystick is badly out of trim, and you've calibrated your Victors to believe that 100 is full forward, 50 is neutral, and 0 is full reverse. You probably won't have also calibrated your autonomous code to output those same values, so your robot will end up doing some very strange things during autonomous mode. (Unless, of course, you have a very sophisticated auto mode with sensor feedback which can compensate for the miscalibration.)
Unread 16-11-2004, 14:38
SpaceOsc's Avatar
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
Re: Spikes
Our Team had horrible Nightmares with this calibration issues,our victor have never been right and have always needed to be calibrated,always been a hassle for the programmers and for the pilot, but the biggest problem was that we played for two years with this problem and we couldnt drive straight ever, our pilots and programers did there best to compensate. glorious was the day i came and stuck a paper clip in a victor during competetions and all sudden everything was right.so YES ALWAYS CALIBRATE!!!! and do it before u start programming.tho i figure most programs are written to the ideal numbers that are supposed to be used.
Does Anyone know how to reset IFI parts such as Victors to Just out of Factory Conditions?
Unread 16-11-2004, 14:55
Re: Spikes
It's in the victor manual.
Unread 16-11-2004, 16:29
Electrical Engineer
Rookie Year: 1995
Re: Spikes
Like I said above, more than one way to skin a cat...
I agree completely with Mr Gross. The Bobcats have never calibrated a Victor in all these years. We depend on the fact that 0 will give you -12V to the motor, 127 will give you 0V and 254 will give you +12v.
What some of you are addressing is joystick calibration which we address as a software issue or not as all... Even if you were to get perfect calibration of the joysticks, you have the motor issues to deal with (they are faster in one direction than in the other).
We have found that the drivers, if given sufficient practice time, can do wonders with complex and non-linear systems.
Last note: With default settings on the Victors, they can be swapped with impunity. With proper trim on the Joysticks, they can be swapped with just as much confidence. It makes troubleshooting much much easier and safer...
JMHO
Mike Betts
Unread 16-11-2004, 17:37
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
Re: Spikes
From Innovation First Victor 883, 884 Users Manual:
Resetting Calibration to FIRST Pre-calibration:
1. Power OFF the speed controller.
2. Press and hold the Cal button.
3. While continuing to hold the Cal button, Power ON the speed controller.
4. A flashing GREEN indicator denotes calibration is reset. Release the Cal button.
Unread 16-11-2004, 19:47
SpaceOsc's Avatar
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
Re: Spikes
Originally Posted by gwross
thats great, but my thoughts were on figuring out why id had to recalibrate victors all sudden (calibration of joysticks have been ruled out)
Unread 16-11-2004, 20:58
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
Re: Spikes
...my thoughts were on figuring out why id had to recalibrate victors all sudden (calibration of joysticks have been ruled out)
Apparently, you are now referring back to your earlier post:
...I've had times when Victors all of a sudden need to be recalibrated for seemingly no reason.
That certainly wasn't apparent from the question I was trying to answer:
Does anyone know how to reset IFI parts such as Victors to just out of factory conditions?
At any rate, I know of no reason why a Victor would reset itself. It seems unlikely that the procedure I cited from the Users Manual could have been executed inadvertently. Has anyone else witnessed a Victor inexplicably losing its calibration?
24Vs and victors greencactus3 Control System 13 05-02-2005 14:22
Victors for Chips Cutting Off aaronbr28040 Control System 13 20-02-2004 16:52
victors great_one411 Electrical 4 06-02-2003 09:08
Flakey Victors archiver 1999 4 23-06-2002 21:58
DON'T Recalibrate Victors! Joe Johnson Off-Season Events 0 12-11-2001 22:58
