Go to Post And you wonder why these guys are figuring out where to hang another Chairman's banner. :) - Billfred [more]
Unread 18-11-2004, 10:34
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: pic: Team 60 Wheel Design
My team was looking at wheel designs and I pointed them to 60's. We figured out your design from one of the pictures of the robot, but I wasn't sure how they might be fabricated. I'm not too familiar with lathing, can that lip to hold the belt material cut with a lathe?
Also, in some other thread about your wheels, someone said that you screwed that the belt material was screwed in radially in a few places to help hold it down. I assume you drilled these holes through the rim on the thicker piece.
Finally, what do you use for a hub? Is it bolted around the central hole? What shaft diameter/keyway and length of keyway did you use?
Thanks.
Team 1257
How Many FIRST shirts do you own? Joe Ross General Forum 81 31-08-2004 10:36
pic: Team 237's wooden team buttons we handed out in Atlanta. What number did you get? CD47-Bot Extra Discussion 12 28-07-2004 04:12
Loss of Gracious Professionalism Among First Teams Melissa Nute General Forum 82 31-03-2003 19:34
Disqualifications archiver 1999 13 23-06-2002 21:53
