Go to Post you don't need a fancy workshop to build a good robot, just determined people. - pacoliketaco [more]
Unread 17-11-2004, 15:35
Alexander McGee's Avatar
Alexander McGee Alexander McGee is offline
Hoonigan
AKA: Alexander S. McGee
no team (no team)
Alexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond repute
Send a message via AIM to Alexander McGee Send a message via Yahoo to Alexander McGee
Light Sensor Type, Please Help!
Hey all.
I'm working on a test fixture here at work (im in R&D) and we need a light sensor to determine the position of a door.
I would like to use the ones that FIRST provided, as they were simple and can handle our power supply.
So here is the question: where do i get this? Who is a good distributor and what is the part number?
I have searched a little, and was unable to find any specifics on this.
Any help is grealy appreciated!
-Alex
-Alexander S. McGee
Intellectual Property Attorney, Mechanical Engineer, Gear-head
Unread 17-11-2004, 16:04
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Re: Light Sensor Type, Please Help!
http://www.baneng.com/products/photoelectrics/ They are here somewhere and you might as well get the sensors direct from the vendor.
Unread 17-11-2004, 18:55
vtrehan's Avatar
vtrehan vtrehan is offline
Mentor - Controls & Programming
AKA: Vivek Trehan
FRC #1241 (Theory6)
vtrehan is on a distinguished road
Send a message via Yahoo to vtrehan
We used digikey.com, they supply from various vendors at good prices, heres the link: http://dkc1.digikey.com/US/PDF/T043/P5.html
2006-GM Industrial Design Award - Greater Toronto Super Regional
2006-Engineering Inspiration Award - Arizona Regional
2006-Regional Finalist - Arizona Regional
2005-Best Defensive Robot - Wonderland Off-Season
2005-Regional Chairman's Winners - Greater Toronto Regional
2005-Regional Champions - Waterloo (Thanks 68 and 1305)
2005-Best Website - Greater Toronto Regional
2005-Team Spirit Award - Waterloo
2005-Entreprenuership Award - Waterloo
2004-Rookie All-Star award - Great Lakes Regional
2004-Rookie Highest Seed - Greater Toronto Regional
2004-Rookie All-Star award - Greater Toronto Regional
2004-Team Spirit award - Greater Toronto Regional
2004-Team Spirit award - National Championship
Unread 17-11-2004, 18:59
Here are a couple of websites of interest.
http://www.bannerengineering.com/pro...lectrics/qs18/
http://www.bannerengineering.com/tra...?topicID=A1_00
Unread 18-11-2004, 08:09
Hey all.
-Alex
Alex,
Are you trying to just determine two positions i.e. opened and closed? Are you trying to determine absolute position? Each of these will need different devices. The Banner sensor line has several devices that are used as proximity sensors that would work well for open and closed. Depending on your application, rangefinding might be a better way to go if the distance is greater than a few feet. Digikey has a large variety that may not stand up in an industrial environment without other enclosures. McMaster Carr has a variety of devices that are designed for use on production lines that may be more suitable.
Unread 18-11-2004, 08:58
Hoonigan
no team (no team)
Basically, yes, just two positions. We use sterilizers here at work to to product life testing on our hand-pieces (drills, ect). We just got a new one and my job as a co-op is to build a robot to to repetitive test. It basically inserts a tray, closes the door, starts a cycle, waits for it to end, opens the door, removes the tray, cool the items, and then restarts the process.
The fixture will be mounted a few inches (likely 3) from the door. The door drops down into the machine to allow for tray insertion. I need to put a mark on the door so we can verify that it is indeed closed or open. I would like to use the light sensor to detect these marks on the door, or even just a single mark.
Also, the system is 24v, but can be easily modified for something else.
I would like the sensor to be able to output a digital signal, rather than an analog one. However, if this is not possible, i would likely need an amplified signal so that i may use it in line with a relay control.
Any suggestions on the type of sensor and part numbers?
-Alexander S. McGee
Unread 18-11-2004, 12:22
Alex,
Any of the short distance Banners would work just fine but are rather expensive when a micro switch would likely be just as effective and more reliable.
Unread 20-11-2004, 21:48
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
I'm with Al on this one. Also, a micro switch, even a limit switch, could handle the 24v without having any modifications. Not so with the banner sensor.
Sparks
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
How many users does it take to change a Light Bulb? Matt Attallah Chit-Chat 4 04-09-2004 20:59
Please...no more steenkin' light! Andrew General Forum 37 17-04-2003 23:06
light visibility Erinn888 General Forum 30 17-02-2003 15:56
Important info about light Jay Lundy Technical Discussion 10 12-04-2002 11:37
How many posters does it take to change a lightbulb? Brandon Martus Chit-Chat 7 22-02-2002 19:48
