Go to Post Maybe LabView needs to have a watchdog for goofy programmers... - johncap100 [more]
Go Back   Chief Delphi > Competition > Team Organization
Unread 18-11-2004, 13:36
tchescow's Avatar
tchescow tchescow is offline
out of control
AKA: Gianfrancesco Venturin
#1156 (Under Control)
tchescow is on a distinguished road
Send a message via ICQ to tchescow Send a message via MSN to tchescow
Question Team organization
We've been working this season to find a better organization method. The past years we divided the teams in areas such as electrical, fundraising, and others, but sometimes it seems to me that it could be better! So, do you have any suggestions? How does it work with your team?
C ya! Tchescow!
Under Control - #1156 - Brazil
2005 NJ Engineering Inspiration Award
2004 J&J Mid-Atlantic Judges Award
2003 J&J Mid-Atlantic Rookie All-Star
http://www.undercontrol.com.br
A little inaccuracy sometimes saves tons of explanation.
Saki, "The Square Egg", 1924
Unread 18-11-2004, 14:39
Allison K's Avatar
Allison K Allison K is offline
AKA: Allison Kneisler
FRC #3538 (Avondale RoboJackets)
Allison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond repute
Re: Team organization
At this point ACE is rather small team and therefore does not require a large complicated organization system. As the team grows we'll have to make things a bit more detailed. For now we have three major groups - Technical, Management, and PR. Technical does all the robot stuff (Drive/chassis, manip, electrical/programming, and support) and all of the computer stuff (website, Inventor, and animation), Management does fundraising and the paperwork, and PR is in charge of team image and the Chairman's award. All of the students are in at least two of the major groups, and the mentors rotate between all of the groups. Most people just end up doing a bit of everything, or whatever needs to be done at the time. Most of the time I just use organization into subgroups when we're planning educational stuff specific to different subgroups (ie - the drive/chassis team learning about different types of drives, or the support team working on the cart and crate).
~Allison K
PS - It does seem as though we've discussed this before however I searched and couldn't find anything.
FRC3538 : RoboJackets : 2014-??? : Head Coach & Drive Coach
FRC226 : Hammerheads : 2003-2013 : Strategist
Unread 18-11-2004, 14:45
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
The most important thing I have learned from my team's reorganization experience is to make sure you split the team by function and not so the team fits into some convenient or existing organizational model. For example, the Website, Animation, and Robot teams are almost entirely independent. They almost never need to meet together, and there is no reaosn they should have a common leader. On the same token, PR and Fundraising are often split, but their activities often consist of the same thing: communicating with the outside world.
Team 1257
Unread 18-11-2004, 14:46
Dorienne's Avatar
Dorienne Dorienne is offline
6 years and counting! :)
AKA: the only fish in FIRST
FRC #0007 (Team 007); FRC #1719 (Umbrella Corp)
Dorienne has a reputation beyond reputeDorienne has a reputation beyond reputeDorienne has a reputation beyond reputeDorienne has a reputation beyond reputeDorienne has a reputation beyond reputeDorienne has a reputation beyond reputeDorienne has a reputation beyond reputeDorienne has a reputation beyond reputeDorienne has a reputation beyond reputeDorienne has a reputation beyond reputeDorienne has a reputation beyond repute
Send a message via AIM to Dorienne
Team 007 does what yours has done so far; separate into groups. What we also do is make sure each group does their job, and when the day is over, we collect all our information together and make a list also of what needs to be done still. We just make sure everything is done by a certain day, which is still something we need to work on...:-)
Just make sure you know what every group is doing and that they're doing their job. At the end of the meetings, collect all the tasks accomplished at the end of the day, and then make each group get an idea of what has to still be finished, and give a deadline that works for the group. =)
Have you found NEMO yet?
Proud mentor to teams 007 and 1719!
Unread 18-11-2004, 14:50
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
Our team has various sub teams. The best way to sucessfully operate any organization, from a leadership standpoint, is delineation of jobs. Any time a job comes up, either take a voulenteer for that job or assign it to someone. Then who ever is incharge of your team has to do is keep track of who is doing what and track progress. This is much easier than doing work and having to track them as well. It might be a good idea to form a sort of board that is made up of the heads of your subteams that meets weekly. Then theres one central place that you can do the tracking.
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 18-11-2004, 15:24
lilszek24's Avatar
lilszek24 lilszek24 is offline
Lost in the sea of orange
AKA: Claire Szeker...
FRC #0230 (The GaelHawks)
lilszek24 is on a distinguished road
Send a message via AIM to lilszek24
Our teams organization, well it isn't very very organized at times but it works. Were split up into sub committees Webpage, animation, spirit, construction, newsletter. Then on top of whatever committees you are in you pick either scouting or spirit for what you will be doing at competitions. In each subcomittee is a team leader i guess you could call it. who at every team meeting updates the entire team on how that particular comittee is doing. Along with the team leader the comittees usually have one or two parents. who work with them. Most people get involved with two comittees, its usually construction and whatever else you pick...it seems to keep us going.
Claire Szeker
"im the slow one on the team i suppose"
Unread 18-11-2004, 15:30
Steve Howland Steve Howland is offline
Many years, many teams
FRC #2473 (Goldstrikers)
Steve Howland has a reputation beyond reputeSteve Howland has a reputation beyond reputeSteve Howland has a reputation beyond reputeSteve Howland has a reputation beyond reputeSteve Howland has a reputation beyond reputeSteve Howland has a reputation beyond reputeSteve Howland has a reputation beyond reputeSteve Howland has a reputation beyond reputeSteve Howland has a reputation beyond reputeSteve Howland has a reputation beyond reputeSteve Howland has a reputation beyond repute
Our team divides into varios groups such as computers (website, animation, programming), Engineering (building the bot), Business/Fundraising (budget, hotel plans, etc.), Art/Spirit (shirts, signs, awards), and documentation (chairman's, rules stuff)
After we decide what each group incorporates, we go to everyone in the rom and they must sign up for at least one thing, many people having 2 or more. Then during meetings we often divide into these areas and people go where they feel they are most needed. This gives everyone something to do and lets new team mebers become involved instead of watching and not accomplishing anything. To make this easier to understand we have a business map that we sometimes use which highlights al of these areas in a diagram - I'll see if I can get a copy. Hope this helps.
-Steve
Unread 18-11-2004, 15:44
Alexander McGee's Avatar
Alexander McGee Alexander McGee is offline
Hoonigan
AKA: Alexander S. McGee
no team (no team)
Alexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond repute
Send a message via AIM to Alexander McGee Send a message via Yahoo to Alexander McGee
We (my fellow mentors and myself) have complied a binder which includes what you are speaking of. I am at work, so i just scanned it into a PDF document. I've indicated the link where it can be found. Take a look, and let me know if it helps clarify how we do things!
http://grovelandfire.org/metalmuscle/structure.pdf
Make sure to look through the pages, most of that info is on like page 5.
(note: this primarilly focuses on the event season, build season simply consists of a software and electronics team, a drivetrain and chassis team, animation and design team, and manipulator / "arm" team)
-Alex
-Alexander S. McGee
Intellectual Property Attorney, Mechanical Engineer, Gear-head
Unread 18-11-2004, 15:49
Ryan Foley Ryan Foley is offline
FRC #5687 (The Outliers)
Ryan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond repute
Heres my old team's organization chart we made in May for this season. I know it's hard to read but here's the breakdown:
Captain (also coach for the Drive Team)
Assistant Captain (also in charge of scouting at competitions)
Project Manager: in charge of Build Team (which is also the pit team at
comps).
Marketing Director: in charge of Public Relations (photo, video, promotion,
website, awards submissions)
PerFeCCCT Leader: in charge of PerFeCCCT (Practice Field, Crate, Cart
Construction Team).
At competitions we have 1 drive team. Everyone not on the drive or pit team helps with scouting.
Ryan
FRC #5687: The Outliers [2015-?]
FRC #1995: Fatal Error [2007-2009]
FRC #350: Timberlane Robotics [2001-2004]
FRC/FLL volunteer since 2005
Unread 17-01-2005, 19:51
MrAmazing's Avatar
MrAmazing MrAmazing is offline
#0104 (Team Universal)
Team Role: Marketing
MrAmazing is on a distinguished road
This year we are sticking to the groups. The builders will build, the programmers will program, the electronics will do electronics, and so on. We are hoping that this works in organization. So far it seems like it is going well and I hope it does.
Unread 17-01-2005, 20:07
Matt D's Avatar
Matt D Matt D is offline
college time!
FRC #0254 (Cheesy Poofs)
Matt D is a name known to allMatt D is a name known to allMatt D is a name known to allMatt D is a name known to allMatt D is a name known to allMatt D is a name known to all
Over the past few years we have developed a team handbook which contains our organizational structure. The TechnoKats gave us their handbook several years ago, which we used as the basis for ours.
It is available online on our team website.
I hope that helps.
Our basic organizational structure is based on subteams, each of which has its own projects (like animation, drivetrain, fundraising, community outreach, etc). This year, we also have a co-presidency so one person does not have to be responsible for every little aspect of the team.
-Matt Durstenfeld
Unread 17-01-2005, 20:09
jrocket567 jrocket567 is offline
FRC #0617
jrocket567 will become famous soon enoughjrocket567 will become famous soon enough
we (Team 617) are attempting a new organizational structure this year.. we have one "executive officer", pretty much the CEO, who keeps everything running smoothly.. under him are 5 'vice presidents': Engineering, Design and Fabrication (thats me); computer science; administration; awards; and marketing. were still gettin used to this new system, so far it has worked ok.. we are writing the book as we go, so half of the time we are attempting to decide whos job is it to do what, and a few jobs have fallen through the cracks.. i think it will work out once this first year is finished.. PM me after the season and ill let ya kno exactly how it went
good luck
j
Bcahn836's Avatar
Bcahn836 Bcahn836 is offline
Iraq is fun.
AKA: Brad Cahn
no team (Robobees 836)
Bcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond repute
Send a message via AIM to Bcahn836 Send a message via Yahoo to Bcahn836
Team 836 is divided into several sub teams
*Design Strike Team
* Public Relations
*Marketing
*Mechanics
a. Drive train
b. Arm and End
c. Manufacturing
*Electronics
*Programming
*Design
i think that about covers all of it.
Am I the only person with this job? A. Leese General Forum 55 22-06-2006 20:10
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
Real names, please Andy Baker General Forum 131 21-07-2004 22:07
Thank a Team with an i-Pod !!! OZ_341 General Forum 8 20-04-2004 23:57
