Go to Post We found our bandsaw on Craigslist for $40. We keep looking for laser cutters and waterjets in that price range, but so far no luck. - chapman1 [more]
Unread 18-11-2004, 08:34
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: Team 60 Wheel Design
Unread 18-11-2004, 08:42
Charlie B Charlie B is offline
Charlie B will become famous soon enoughCharlie B will become famous soon enough
Re: pic: Team 60 Wheel Design
Can anyone help me better understand Team 60's wheel design? George sent me drawings, but I still would like to know...
Who is the vendor and what is the part number of the conveyor belt material that goes around the perimeter?
How is the material held in place? I see the ridges to hold the edges, but I'm sure there's more. Do screws or rivets go through the material, into the thick part of the wheel?
What is the coefficient of friction of the conveyor belt material against carpeting?
Charlie Buckner, P.E.
Team 900 Mentor
Durham, NC
Unread 18-11-2004, 09:15
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
www.mcmaster.com
Search "Wedge top" (with the space) or skip to page 1089.
This "wedgetop" inclined conveyor belting is the stuff sometimes refferred to as "60 tread". It has been used by many teams, including Kingman, with great effect.
Also, on that same page, check out "Roughtop" conveyor belting. This is also good stuff. (I've heard to use the gum-rubber, "tan").
Both of these materials have coefficients of friction between 1.2 and 1.4.
Though there have been many arguments about which material is better, you should probably do your own testing, and decide from there. The 2 major qualities you'll want to experiment with are: coefficient of friction, and wear characteristics. In 2003, the wire mesh on the ramp ate "wedgetop" for breakfast. You needed to swap out wheels every few matches to keep them in good shape.
Good Luck,
John
Unread 18-11-2004, 10:34
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
My team was looking at wheel designs and I pointed them to 60's. We figured out your design from one of the pictures of the robot, but I wasn't sure how they might be fabricated. I'm not too familiar with lathing, can that lip to hold the belt material cut with a lathe?
Also, in some other thread about your wheels, someone said that you screwed that the belt material was screwed in radially in a few places to help hold it down. I assume you drilled these holes through the rim on the thicker piece.
Finally, what do you use for a hub? Is it bolted around the central hole? What shaft diameter/keyway and length of keyway did you use?
Thanks.
Team 1257
Unread 18-11-2004, 11:08
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
I never knew the name of it, but it looks like the belting that we've been using on our wheels for the past few years. It works very well on the surfaces that we've been playing on.
We've attached the belting to the wheel using rivets. It makes it easy to change treads when they get worn...just drill out the old one and pop in a new one. You can see a rivet in the right wheel in the attached picture just above the frame.
Maybe one of our more mechanically oriented guys can step in and give any details that I missed
Unread 18-11-2004, 19:07
joker joker is offline
FRC #0022 (Double Deuce)
joker is an unknown quantity at this point
Send a message via AIM to joker
If anyone wants to email me at je.nelson@earthlink.net i have the autocad drawings and can explain what ever u need to know about the wheel. How it work to how to make it.
Unread 18-11-2004, 19:57
DCA Fan's Avatar
DCA Fan DCA Fan is offline
FRC 812/3476 Mentor
AKA: George
FRC #0812 (Midnight Mechanics)
DCA Fan has a reputation beyond reputeDCA Fan has a reputation beyond reputeDCA Fan has a reputation beyond reputeDCA Fan has a reputation beyond reputeDCA Fan has a reputation beyond reputeDCA Fan has a reputation beyond reputeDCA Fan has a reputation beyond reputeDCA Fan has a reputation beyond reputeDCA Fan has a reputation beyond reputeDCA Fan has a reputation beyond reputeDCA Fan has a reputation beyond repute
Team 22 is doing a similar design of trapping the conveyor part inside the rims. Talk to them for more info.
2016 FRC Orange County Regional Co-Chair, FRC San Diego Emcee, FRC Ventura Emcee, Vex Worlds Emcee
2015 FRC Emcee: Inland Empire, San Diego, World Championship. VRC Emcee World Championship
2013-2016 FLL Judge Advisor, Southern California/Legoland
2001-2005 FRC294 Beach Cities Robotics
2005-Present FRC812 Midnight Mechanics
2012, 2014 FRC3476 Code Orange
2003-Present Volunteer, FRC/FTC/FLL/VRC
NEMO | San Diego Regional | Orange County Regional | FIRST California
How Many FIRST shirts do you own? Joe Ross General Forum 81 31-08-2004 10:36
pic: Team 237's wooden team buttons we handed out in Atlanta. What number did you get? CD47-Bot Extra Discussion 12 28-07-2004 04:12
Loss of Gracious Professionalism Among First Teams Melissa Nute General Forum 82 31-03-2003 19:34
Disqualifications archiver 1999 13 23-06-2002 21:53
