Go to Post I even liked the Bieber commercial. - Andy Baker [more]
Unread 18-11-2004, 20:16
Golden's Avatar
Golden Golden is offline
#0011 (MORT)
Golden will become famous soon enough
Send a message via AIM to Golden
Kits of Parts: Part Specs
Has any team comprised a list of the specs for the parts in the kit from last year? We are desperately trying to make one, but have run into a lot of dead-ends with certain companies, especially parker.
Golden
Unread 18-11-2004, 20:32
SCYTE16's Avatar
SCYTE16 SCYTE16 is offline
AKA: Gordon Tennyck
#0011 (MORT)
Team Role: Student
SCYTE16 is on a distinguished road
Talking Re: Kits of Parts: Part Specs
so do we if you find it plz tell me JK
Unread 18-11-2004, 21:08
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
http://www.usfirst.org/robotics/2004/specsheets.htm
You should find a lot of the specs here.
Wetzel
Unread 19-11-2004, 11:58
jdiwnab's Avatar
jdiwnab jdiwnab is offline
Really the Inventor Guy
AKA: Bryan Hartley
FRC #0617
jdiwnab is a jewel in the roughjdiwnab is a jewel in the roughjdiwnab is a jewel in the rough
This isn't offical but our 120A circuit breaker broke after dropping about 4 volts. Not good. So we took it apart to find out how it worked and then didn't.
Post-mortem autopsy of a Buss 120A circuit breaker
Operators- David Keagan, Jay Penick, Bryan Hartley
Date of autopsy- November 10, 2004
Writers- Bryan Hartley, David Keegan
Date of Write-up- November 15, 2004
Following the death of a Buss 120A circuit breaker, an autopsy was performed to determine the cause of death. The circuit breaker arrived in a decomposed state. The positive terminal casing was mangled and a large split was found across the side with the positive terminal.
Because of the level of external decomposition, it was necessary to review the inside. An incision was made to remove the front portion of the breaker. Three of the four pins holding it in place were cut. This front portion was rotated away and it revealed a rubber insulating membrane. This was cut away to reveal the inside of the breaker. Unfortunately, the decomposition had continued to the inside in parts. The positive terminal was attached to a metal plate that appeared to be a bimetallic spring. A wide “T” shaped metal object was removed to remove the positive terminal and the metal plate. The red button that reset the breaker and was visible externally was removed along with the power on switch. A broken shaft was found that appeared to have been connected to the power on switch and was part way attached to a small spring. These were removed, along with the positive terminal and the metal plate.
The apparent cause of death at this time was the charring of the metal plate. Upon closer examination of the metal plate, it is found to most likely to be a bimetallic spring. To better determine the cause of death, the circuit breaker needed to be reassembled to find out how it worked.
The bimetallic spring and positive terminal were inserted into the body of the breaker. The negative end the the spring connected to a contact near the negative terminal. However, it did not attach to it. The red reset button was inserted into the front portion, along with the power on switch. Part of the shaft was placed near the negative terminal, centered on the bimetallic spring. This portion had a flange that appeared to overlap some of the spring. It was found that the “T” shaped part could hook another “T” shaped attachment on the bimetallic spring and would rest on two side holders. This would allow the reset button to push down on the “T” , which would make the bimetallic spring be removed from the negative contact. The power on switch would cause the shaft to push down on the spring, creating contact.
With these findings, a consistent cause of death was reached. Because of metal fatigue, the spring lost it’s elasticity. In use, the motors current draw increased at some point, causing heat. This made the spring bend, but not enough to cut off the current, only to created an ‘air resistor’. Because of the loss of elasticity, the spring didn’t reengage fully and so overheated dangerously.
So, don't over use your circuit breaker and have replacements.
Proof that Macs will win the platform war: How did Scotty know how to use MacDraft in Star Trek IV?
// random()
I have 100 gmail invites. PM me if you want one.
If they want us to think outside of the box, why do they make us fit in a 38x28x60 inch box?
Beware of Geeks bearing GIFs
Help me test my server software
Unread 19-11-2004, 19:42
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I agree with you in full on that statement. The circuit breaker is not a switch. It isn't designed to be turned on and off like one - and yet we do it hundreds of times over. I can't complain though because we used to have those 60A ones that were more suited for a house. The 120A one we get isn't really too bad.
Unread 22-11-2004, 14:04
jdiwnab's Avatar
AKA: Bryan Hartley
FRC #0617
Speaking of which, Is there a better 120A circuit breaker that can be used on post-compatition robots? The one that broke was from the 2004 compotition, which we replaced with the one from the 2003 compotition that is on it's way to destruction. Amaizingly, both of our 60A breakers (which I don't really like too much) are in better condition than our 120A's. We need to replace both of the 120's at some point, but we don't really want to ues them unless we have too.
// random()
Unread 22-11-2004, 17:26
Squirrelrock's Avatar
Squirrelrock Squirrelrock is offline
I may be teh programmer?
AKA: Keegan
FRC #0414
Squirrelrock will become famous soon enoughSquirrelrock will become famous soon enough
Send a message via AIM to Squirrelrock
<sarcasm>
you spell amaizingly well, jdiwnab!
</sarcasm>
too bad spell check doesn't work in safari.
Look what I did to Dave:
Aaacckkk! Guurrkkk! Sssnorrrrkkkkk! Brain ... explode ... will. AAAArrrrggghhh!! Must ... not ... think ... about ... 2007 ... yet. Uuurrgghh!!! Still ... have .... to ... resolve ... how ... to ... pack ... parachutes ... for ... 2006 ... Ooorrrkkggnn!!
Sweet!
The scientists of today think deeply instead of clearly. One must be sane to think clearly, but one can think deeply and be quite insane.
- Nikola Tesla
Genius might be described as a supreme capacity for getting its possessors into trouble of all kinds.
- Samuel Butler
Unread 22-11-2004, 17:58
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Originally Posted by Squirrelrock
<sarcasm>
</sarcasm>
Well, amazingly, at least.
Unread 23-11-2004, 11:41
jdiwnab's Avatar
AKA: Bryan Hartley
FRC #0617
I Know I can't spell, but there are worse things than that. Normally, I could use spell check, so I don't need to spell well, only OK. But no one answered by question. Is there a better circuit breaker out there that we can use. Or at least direct me to a good thread with relivant information.
// random()
PLEASE RESPOND: NRLB & Spare Parts at Nats ngreen Championship Event 12 23-04-2004 16:06
2004 Motor specs - Part 1 Paul Copioli Motors 12 28-01-2004 17:40
Rules on making spare parts fyi DougHogg General Forum 0 02-04-2003 16:18
What advice would you give? Jessica Boucher General Forum 8 02-12-2001 07:10
Pneumatic Parts Part 2 HK_SRT_LDR_A OCCRA 1 16-10-2001 06:12
