Go to Post This is Chief Delphi. We're all crazy here. - Whippet [more]
Unread 19-11-2004, 16:55
CmptrGk's Avatar
CmptrGk CmptrGk is offline
Programming Mentor
AKA: Dillon
FRC #0716 (Who'sCTEKS)
CmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud of
auto backup
since the build season is coming soon and the only way for me to get files off my laptop is through a compact flash card. i need to be able to write an automatic backup utility. what i mean is when i insert the reader into my other laptop i want it to automatically everything on the card onto the harddrive.
edit
i have been able to write a batch file that will backup the data i just need it to run automatically
edit #2
does any1 know of a way that i could trick windows into thinking that the cf card is a cd becasue in xp/nt based oses it wont allow autorun from removable media
"Great autonomous mode Dillon."," It hasn't been written yet"
after an Archimedes match
Unread 19-11-2004, 21:37
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: auto backup
They will. In fact, my version of XP looks for autorun anywhere when ever I stick in a USB key.
It's a registry hack, and in MSDN. (like here.)
Unread 19-11-2004, 21:45
CmptrGk's Avatar
Programming Mentor
AKA: Dillon
Re: auto backup
what i mean by autorun is when you have a file called autorun.inf on the cd or whatever this quote
Note Autorun.inf files are not supported under Microsoft Windows XP for drives that return DRIVE_REMOVABLE from GetDriveType.
so this is why i need to trick it into thinking its a cd
Unread 19-11-2004, 21:50
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: auto backup
While it may be a great idea, making it happen sounds like more work than just manually double clicking on CF drive and hitting Ctrl-A-C and double clicking on HD and hitting Ctrl-V each time. It is really a quick process hitting the mouse button and keys, and it will copy everything in the background while you go about your other tasks.
Unread 19-11-2004, 22:02
AKA: Jamie Bliss
Re: auto backup
What you could do is have an application wait for the usb key to come, then do the backing up/syncronizing. (a local CVS repository could be handy for this...)
Unread 19-11-2004, 22:06
CmptrGk's Avatar
Programming Mentor
AKA: Dillon
Re: auto backup
i have no clue how to use these.
if i cant figure it out tonite il just use the short cut to the batch file i made
Unread 19-11-2004, 22:35
AKA: Jamie Bliss
Re: auto backup
If you have access to VB, you can use the Microsoft SysInfo control for the notifications.
CVS is a command line utility.
Check the appropriate help for details.
Unread 19-11-2004, 22:41
CmptrGk's Avatar
Programming Mentor
AKA: Dillon
Re: auto backup
i dont have access to VB
Unread 19-11-2004, 22:45
Re: auto backup
Would anyone like to address the issue of "why"?
See, you can spend ten years developing a bullet train that will cross the country in half a day - ten years from now. Or you can start walking now and be at the other side in about 3 months. Who gets there first? The walker. Also, the walker can make the trip 40 times before the bullet train ever makes its first trip.
Unread 21-11-2004, 19:46
pi_guy578 pi_guy578 is offline
Programmer/Electrician
AKA: Jake
FRC #0578 (Blue Lightning)
pi_guy578 has a spectacular aura aboutpi_guy578 has a spectacular aura about
Send a message via AIM to pi_guy578
Re: auto backup
We don't get anywhere when we don't try to improve upon old ways, and pessimism gets us no where. There is some software that will do what you want. Finding the free stuff is what's hard.
Backup Battery...Yay or Neh? dez250 General Forum 31 05-05-2004 17:08
Urgent!!! Problem concerning Backup battery and autonomous. Code\\Pilot Programming 3 26-02-2004 16:44
Cutting wire on backup battery MikeDubreuil Electrical 4 23-02-2004 18:55
auto archiving of posts Joe Ross CD Forum Support 4 01-01-2004 02:04
picking auto program Mike375 Programming 19 03-03-2003 15:47
