Go to Post - Only think of Gracious Professionalism as a standard to work toward personally. - Never use it as a gauge to point out someone else’s shortcomings. - Rich Kressly [more]
Unread 20-11-2004, 18:03
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: crate design and construction
The only real special feature on ours was the garage door in the front. We supported the arm with a plank screwed to the floor. So we could unpack the bot in about 30-60 seconds.
Unread 20-11-2004, 18:35
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Team 237 is in the process of designing and constructing a new robot crate, cart, and charging station.
It's the off season project.
While some of us wanted a crate made from 80/20 and lexan like THIS one, we are going to be making it out of wood again and it will be similar to THIS one.
There are many ways to build a crate, and the eventual debate of weight vs. durability will always come into question.
Build what you can with what you have available, and hope that your shipping bill is not that high.
Or.. You can always do like THIS team and make your crate super light.
Btw, more pics can be found here: http://www.team237.com/gallery/Carts-Crates on our team's site,
or here: http://www.chiefdelphi.com/forums/pictures.php?s=&galleryid=139&perrow=5&trows=5&qui et=Verbose&direction=DESC&sort=date on CD's gallery.
Note: The first 3 on CD's gallery are one's that I took pics of and uploaded, thus they are duplicates of pics on our site.
Good luck in the design and build of your new crate!
Unread 22-11-2004, 11:15
BillCloyes's Avatar
BillCloyes BillCloyes is offline
#0677 (The WireStrippers)
BillCloyes has a spectacular aura aboutBillCloyes has a spectacular aura aboutBillCloyes has a spectacular aura about
Every fall, our team (677) tries to do a mini-build project to introduce/refresh everyone with our design and build process. Before the 2004 season we designed and built a new robot crate ("Super Crate II"). The goals were "simple":
- Lightweight
- Inexpensive
- Able to maximize our pit space.
It was also a conscious decision to undersize the crate a bit (44" x 44" footprint) in hopes of having it be placed "nicely" (instead of it having to be jammed in) among the other crates at the (assumedly, the 48"x 48" grid that was) the drayage facility. We hoped this would do this instead of thicker, heavier materials. Last year, it worked.
We ended up with a wooden crate (< $175) where the paired walls (two walls connected by a piano hinge) detached from the base and top and got set up in back corners of our pit, giving plenty of room for our robot, table (provided at comp site) and people to work on the robot.
The walls then held common fasteners, hand tools, and a dry erase board, via some peg board and a closet door shoe rack ($12 @ lowes- like this http://www.lowes.com/lkn?action=prod...158-604613CPDQ but canvas)
It wasn't planned for but the base turned into a stock rack/battery holder.
We shipped all are batteries (5) and robot, but none of our tools, and came in under the limit.
I don't have any pictures of it in use at competition (VCU 2004), we all were too busy getting sick and trying to get our robot to run... As we wind up for this coming season, I will try to post some pictures if anyone is interested.
-Bill Cloyes
677 Team Lead
OSU FIRST Robotics senior member
Unread 22-11-2004, 11:50
Hey Bill, you got any pics of the crate that you would like to share?
If you e-mail me a pic, I can put it in our gallery, or even the gallery on CD.
media AT team237.com
Also, any idea of an approximate weight when empty (re: minus robot, batteries, and what not)?
Unread 23-11-2004, 22:59
dubious elise's Avatar
dubious elise dubious elise is offline
Gone to school, back in 2016
FRC #0269 (Cooney Robotics); FLL #1855 (Cooney Tech/St. Jerome)
dubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond repute
thanks for the props on the crate, elgin
that one has been around for at least 2 years that i know of, if not more (ricky q would probably know best). Very durable and lighweight, I doubt that it will be retired any time soon!
"We can't guarantee success...but we can do something better, we can deserve it." ~John Adams
"The harder you work, the luckier you are." ~Gerald Ford
Notre Dame '10
Unread 23-11-2004, 23:09
And yet I showed this to the people in charge.. and it was shot down..
Oh well, we'll see how our new (wood) one turns out.
Unread 23-11-2004, 23:59
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
So far our guess is the crate will weigh under 200lbs empty. Mark weighed the materials so he has a rough idea. The frame is made of poplar glued and screwed together. We'll post pics when it's finished.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 24-11-2004, 01:44
Did you know that a Poplar tree will completely explode if hit by lightning because of the density of the sap inside?
Anyways, to see some progress on our new Battery cart, Crate, and Cart, go HERE
That was our first meeting, so not a lot happened...
Some planning, and a little bit of building.
Notice Nikki hard at work screwing those aforementioned poplar pieces into place.
Unread 15-12-2004, 00:25
w00t! Our parts came in and tonight, in about 2 hours.. the raw material was cut, fitted, and pieced together to get our cart 90% done.
CAD (11-30-04)
Then 2 weeks later:
Actual cart (12-14-04) Weighing in at only 25 pounds without a platform, it's awesome.
Next up is the crate which is moving right along.
Unread 15-12-2004, 15:11
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
CAD (11-30-04)
Then 2 weeks later:
=O Who's super cool adidas shoes are those?
Actually working on it was really fun, minus the whole nail's being too light and turning 180 degrees and almost putting a hole in my hand... yeah
http://www.mikesorrenti.com/
Unread 16-12-2004, 23:00
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
What SIZES is everyone's crate?
I assume we don't have to build a 4 ft x 4 ft crate do we? What size have you built that seems large enough for everything that you want to put in the crate?
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 16-12-2004, 23:28
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
FIRST releases that information when they release the rules. (So you'll know folowing the kickoff). FedEx imposes certain rules regarding size and weight. Exceeding those rules results in fees. If you're interested in shipping information from last year to give you some concept of what it should be like this year, visit: http://www2.usfirst.org/2004comp/11-...corporated.pdf or you can access all the documents available from FIRST at: http://www.usfirst.org/robotics/doc_updt.htm
Hope that helps.
Gracious Professionalism isn't simply courtesy or tradition, it's a way of life
I met her through FIRST...
We only are where we are by God's providence and by no other...
Unread 17-12-2004, 18:11
Controls Engineer
AKA: chakorules
I seen the rules, in last years PDF. But that wasn't what I was asking. What size crate did you guys build? I assume not everyone builds the MAXIMUM size of 4ft x 4ft do they? I heard one team built a crate 32" x 36" x 60". That's under the maximum size, but is that REALLY big enough for a robot, some tools, a dolly cart? I was simply asking a question about what other teams have built.
Hope that helps.
Favorite CD quote:
Unread 17-12-2004, 21:20
I misunderstood your post, so thanks for correcting me. It all depends on what you're actually putting inside the crate. Since you seem to be intending to store extras like a dolly and tools, you'll probably want to go for the 4 foot wide at least, possibly 4 foot long as well. Height though is completely dependant on the height of your robot and the height of your other things. I realize that doesn't really answer your question but I don't know specifically how much stuff you are actually taking, how big those items are (dolly for example, so I can't give you specific numbers to use. It's gonna have to be a judgement call. Just try to leave some leeway to make it easier to get the robot inside the crate.
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Im pretty sure FedEx limits you to a maximum size that they'll accept for free shipping. You should be able to find this size in last years Manual.
2001-2004: Team 100
2006-Present: Team 254
Vertical Bar Field Construction Madison Technical Discussion 0 31-01-2004 19:23
How do you design your robot? Gui Cavalcanti General Forum 23 16-11-2003 18:33
In the spirit of Gracious Professionalism, I give you: My MultiDrive. Sachiel7 Technical Discussion 6 14-11-2003 19:59
White Paper Discuss: Dual-motor, dual-speed drive transmission design CD47-Bot Extra Discussion 9 03-09-2003 10:40
