Go to Post What Delphi says doesn't matter. What the official Q&A says matters. - Tetraman [more]
Unread 22-11-2004, 01:18
jrmarenda jrmarenda is offline
AKA: Jason Marenda
FRC #1887 (Russet Robotix)
jrmarenda will become famous soon enough
Edu Robot Multiple Inputs
I am having some serious problems with our innovation first Edubot. For touch and IR sensors, we can get the code to work with one sensor just fine, but if we try and use two inputs then we get weird results. I was wondering if anyone else has experienced this same problem? If so, what did you do to fix it? if anything? Thanks for you help.
Unread 22-11-2004, 08:58
Electrical Engineer
Rookie Year: 1995
Re: Edu Robot Multiple Inputs
Check the initialization to make sure that the inputs you are using are, in fact, inputs.
Mike Betts
As easy as 355/113...
Unread 24-11-2004, 13:22
jerry w's Avatar
jerry w jerry w is offline
Free Agent Mentor
no team (Team Krunch)
jerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud of
I saw a similar problem when experimenting with sensors. the A/D converter uses a multiplexor. at each selection, the software must wait for the input to reach the voltage of each sensor. when using high impedance devices, the charge time takes longer.
I extended the wait time in the code, from 10 to 30 and the wierdness went away.
(see function Get_Analog_Value)
note, there is a warning in ...
* FILE NAME: ifi_utilities.c
* USAGE:
* The user should NOT modify this file, so that if a new version is released
Jerry W
Happiest when people tell the truth... However, I am blessed with many friends.
what kind of robot will win? Bcahn836 Championship Event 44 12-04-2004 00:02
Important functions of a first robot? Ianworld General Forum 5 15-04-2003 13:29
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
We're really not that mean. archiver 1999 59 23-06-2002 22:49
