Go to Post The real key to drive team coaching is to tie your jacket around your waist. Got a couple championship rings that way. - TravusCubington [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 26-11-2004, 10:58
Re: Has 6 wheeled designs surpased tank treads
Andrew,
If you ever saw the current demand of a tank tread turning on carpet, you wouldn't even think of using it. You can't beat the traction moving forward or back but you will eat a battery trying to turn in a single match. Those that work have some method of raising the track so only a small portion is in contact during turns. Even four wheel and six wheel drives suffer from high current demands unless they employ some method of raising some wheels in turns or use omni wheels on some of the wheels (i.e. front wheels).
If you were to tell me that in driving your robot draws less then forty amps total current but you wonder why your battery runs dead in less than two minutes, I would be able to tell you are using tank drive without ever having seen your robot.
Tank Treads dddriveman Kit & Additional Hardware 27 06-05-2004 18:16
Major problems with tank tread drive Lord Nerdlinger Technical Discussion 13 23-02-2004 21:15
tank treads vs. threaded wheels lj8758 Technical Discussion 14 24-01-2003 00:30
TANK TREADS...welp. archiver 2001 13 23-06-2002 22:50
