Go to Post FIRST showed me how to succeed at one of the most difficult, yet important things: Life. - Jim McGeehin [more]
View Poll Results: What sensors do you typically use on your robot?
limit switch/touch sensors 38 79.17%
optical sensor 33 68.75%
IR or SONAR Rangefinder 5 10.42%
angular accelerometer 9 18.75%
linear accelerometer 1 2.08%
encoders 25 52.08%
potentiometers 29 60.42%
current transducers 7 14.58%
pressure transducers(pneumatic or otherwise) 11 22.92%
compass 1 2.08%
Other (i'm sure someone will find somehtign i didn't list) 6 12.50%
Multiple Choice Poll. Voters: 48. You may not vote on this poll
Unread 28-11-2004, 00:07
Umm Errr...
Re: POLL: What sensors do you use
Originally Posted by vtrehan
We didn’t have many sensors last year as we were well.... rookies .
This year we are planning to work with an IR sensor mounted on the wheels for distance calculation (and we have a working prototype), and we used opto sensors for line following, we also had some limit switches for various purposes.
We are actually shopping around these days for a more reliable sensor for distance calculation, so if someone can recommend something more reliable and simple, please let us know .
Thanks,
Vivek.
In a word words: encoders. Search the forums and you will find several detailed threads. They are very easy to use and extremely accurate
1139 Alumni
Unread 28-11-2004, 14:46
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
I coded for (Whether or not they were placed on the bot, but most were) numerous sensors.
  • 3 pots (shoulder, arm, & hand position)
  • 1 switch (arm limit)
  • 4 banners (quadrature)
  • 1 current (for the hand, made a overload mech around that)
  • 1 pressure (the simple pnuematic one, only controlled the compressor)
  • 1 Gyro (compass)
I think that's it.
Getting Fancy with Sensors FadyS. Programming 30 10-03-2004 15:02
Why not analog sensors?? gnormhurst Programming 16 07-03-2004 16:14
Interrupts and rotation sensors kor Programming 3 12-02-2004 11:05
wiring diagram for light sensors??? pagemauck Control System 1 21-01-2004 16:32
idea: a semi-official coaches poll archiver 1999 8 23-06-2002 22:23
