Go to Post I was on the same plane as 365 returning from Atlanta to Philadelphia last year. The whole rear half of the plane was neon green. - Lil' Lavery [more]
Unread 29-11-2004, 10:58
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Re: Is a shifting transmission really necessary?
Originally Posted by Andrew
The rules specifically indicate that pushing [shoving] is OK and expected. Why would you say it's not FIRST-encouraged?
This is, in fact, the main reason for a low gear in a transmission.
Actually, last year we used our low gear for climbing so that we could avoid all the pushing and shoving. But with the dynamics of last year's game we felt that anybody who got into a shoving match, was probably doing the wrong thing. The 02 and 03 games were a different story. There was a lot of space to cover and you had to be able to hold your ground when needed.
Design for how you plan to play the game. If you need two or more clearly definable speed regimes, then shift. If not, then don't.
ChrisH
Christopher H Husmann, PE
"Who is John Galt?"
Slickest drive transmission yet... dlavery Technical Discussion 58 10-01-2005 19:33
The perfect 2 speed Transmission..... features... Salik Syed Technical Discussion 28 20-10-2004 11:44
Need info on gears inside drill transmission. sanddrag Motors 7 14-04-2004 11:01
3 shifting transmission... Arefin Bari Technical Discussion 19 04-03-2004 01:24
322 Three speed transmission. dkeith Robot Showcase 8 10-06-2002 22:33
