Originally Posted by sanddrag
I'm not an AutoCAD user but I see it as one of two things
1. For whatever reason that is the way the program is made and it is like that for everyone and you just have to live with it.
I'm relatively fluent with AutoCAD and have never had this problem whever I've used it, so I can eliminate this answer. Have you used the program much before this and not had the problem? Usually as you said, the object is made out of hidden lines or the such when your moving it...making it transparent. Good Luck
