Go to Post There are no rules specifically prohibiting the use of cryogenically preserved legumes on the robot. - dtengineering [more]
Unread 29-11-2004, 20:58
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Multiple version of Inventor on one computer
Is it possible to have multiple versions of Inventor on one computer? I have 5 installed and would like to install 8 while still keeping 5. I know I can open my files in 8, but I still will need to make some new drawings in 5 sometimes. Installing 8 won't overwrite 5 will it?
Unread 29-11-2004, 21:01
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Multiple version of Inventor on one computer
I can only definitively say that you can have multiple versions of AutoCAD on your computer, since I do at work. Since it's the same company, it's atleast conceivable that you could do so.
Unread 29-11-2004, 22:35
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
I have both Version 6 and Version 7 on mine and both are OK!
Unread 30-11-2004, 00:46
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Not sure, But I do know that different version of Solidworks overwrite each other, unless you partition the HD and put them on seperate drives, or seperate sections..
Good luck.
Unread 30-11-2004, 13:31
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
You can have multiple versions of Inventor installed on one PC. Until recently I had versions 5.3, 6, 7, and 8 all on my machine at work, without any problems. The application does re-register with Windows when you switch versions, though.
From the Voice of Experience, one thing to watch out for : If you have v5.x installed and uninstall it, be sure to delete the folder containing the "Content Library" files for that version before you install a more recent version. Otherwise the installer doesn't correctly install the content library for the new version and things can get messy. You shouldn't have this problem if you just leave v5 installed, though. (I found this out the hard way by deciding to get rid of v's 5-7 before installing v9. Now whenever I launch v8 or v9, I get a not quite functional dialog asking me to find the content library.)
Pete Kieselbach
My computer loves Microsoft ARGH!! HELP ME! team222badbrad Chit-Chat 12 29-01-2005 09:17
Q&A Watcher Available for Download Nate Smith General Forum 11 19-12-2002 11:12
List of UTC Hartford Teams archiver 2001 3 24-06-2002 01:09
Full list of teams & competitions archiver 2001 14 24-06-2002 00:52
My other computer will not work with this forum! David Kelso CD Forum Support 4 04-06-2001 21:52
