Go to Post When all you're holding is a hammer, every problem looks like a nail. - artdutra04 [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 28-11-2004, 16:20
colt527 colt527 is offline
AKA: Ken Colton
FRC #0527
colt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to behold
Send a message via AIM to colt527
Re: Has 6 wheeled designs surpased tank treads
I would have to say that 6 wheel drive systems are much better for rookie to intermediately skilled teams for many reasons. The first being that 6 wheel drive systems are much easier to design and build. For a efficient 6 wheel drive system, you don't need any complex tools. All 3 six wheel drive robots were built on a low budget, with only a band saw and drills. You don't need complex custom made mounting brackets displayed in Tom Bottiglieri's picture that look like it was made with a CNC Milling machine. The design of a good six wheel drive system is a very open-ended one. You can easily design a simple 6 wheel drive system on your first try that may weight a considerable amount or have other draw backs but over the years you will figure out ways to cut weight and increase efficiency.
Treads can probably give better traction in pushing situations and although I have no experience with them, there are probably many other pros to treads.
So, I guess it depends on the contest it self and the experience/tools/budget of the team and neither are superior to the other.
Mentor, Team 527 -- Plainedge Red Dragons
FIRST Volunteer
SUNY Stony Brook Computer Science 2010
kcolton@gmail.com
Unread 29-11-2004, 18:08
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
Historically 134 has used tracks most years. We've worked with two diffrent situations with tracks.
In 2004 we used a tread that spanned the length of the bot. Due to the placement of the center of mass and the raised center wheel we were able to turn like a bot with two wheels in the center. This allowed use tremendous pushing power while also allowing us to turn on a dime...literally. We also never had much of a problem with the batteries (granted we only drove with CIMS). We would start a match with 12-13v and never ended with less then 11v. We also never snapped a belt either in 1 regional and three offseason competitions with this drive train.
The second solution that we have attempted is similar to the old German half track. About half the length of the robot would be track and the other side (or if centered both sides) would have casters. This worked well but was not efficient as the 2004 machine.
I prefer the track drive if its designed right.
-Pat
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
Unread 29-11-2004, 19:20
RogerR's Avatar
RogerR RogerR is online now
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Originally Posted by colt527
I would have to say that 6 wheel drive systems are much better for rookie to intermediately skilled teams for many reasons. The first being that 6 wheel drive systems are much easier to design and build. For a efficient 6 wheel drive system, you don't need any complex tools....
psst...don't tell these guys that treads require complex tools...
the truth is that a 'bot is only as complicated as you make it. granted, it may be easier to over-complicate a tank-bot, if you design with simplicity and machinability in mind, i expect it could be built with band-saws and drills.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 29-11-2004, 20:30
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
In the above robot, what advantage does that have over a good wheel? It is a nice attempt but I don't see the benefit.
Unread 29-11-2004, 20:31
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
look at the evolution of the competition, apparently tank treads were popular when we had ramp style competition. where as 6 wheeled designs have come into play mostly with the new start style.
Unread 29-11-2004, 20:53
[527]phil's Avatar
[527]phil [527]phil is offline
Alumni
AKA: Phil
FRC #0527 (red dragons)
[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light
Send a message via AIM to [527]phil
Tank treads can be complicated, depending on what your recourses are, for instance a simple bot as shown above is easily made, but wouldn't stand up against last years competition. one of the teams at our regional last year used treads, their goal was to climb the steps, but weren't able to and ended up just pushing around balls. I personally favor treads for their easy drivability. And Ken, i could easily make the mounting brackets if you drew them for me, being i have a maxnc cnc milling machine in my basement, which everyone on my team seems to forget.
Whats the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons, civil engineers build targets
Unread 29-11-2004, 22:09
RogerR's Avatar
AKA: Roger Riquelme
maybe you and i don't see the advantage, but apparently they did, else they wouldn't have built it.
but that wasn't the point i was trying to make. i was trying to point out that complexity lies in the design, rather than the type of drive train.
Unread 30-11-2004, 00:01
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
116 used a tank design in 99 to climb the puck. It was used again in 2001 to be able to go over the 4x4 but under the bar.
Tank drive was used as a function of the design.
Last year was four wheel drive, with large wheels to get up to the bar. Function of the design.
Stratagy drives design, not features.
Wetzel
Unread 30-11-2004, 00:36
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
small little story:
my legoleague team #2883 competed in a competition with there very complex robot with tank traads. the thing is awesom but it never goes straight no matter what you do and the kids get nervous and due to its complexity they wasted alot of time durring the match in setup.
now they've changed to a 6-wheel drive with the center wheels lowered. and only 1 moterised moving part beyond that a very simple thing. and it GOES STRAIGHT! i think in their next competition they are going to do much better
Unread 30-11-2004, 08:59
Originally Posted by Tytus Gerrish
small little story:
As has been stated before, designs are just as complicated and efficient as you make them. In my teams case, we have been successful with treads. Other teams have been successful with 6 wheel drive.. I dont believe either one is "better".
Tytus brings up a good point.. In his Lego league team's undertakings, 6 wheel drive has been superior to the treads. This is not because treads are a horrible idea and 6 wheel drive is much better, it is simply because that teams design and method of construction may have been different from that which would make "the perect system"
Unread 30-11-2004, 12:34
occra 23.
AKA: ryo
None #1481
Originally Posted by Tom Bottiglieri
As has been stated before, designs are just as complicated and efficient as you make them. In my teams case, we have been successful with treads. Other teams have been successful with 6 wheel drive. I dont believe either one is "better". Tytus brings up a good point. In his Lego league team's undertakings, 6 wheel drive has been superior to the treads. This is not because treads are a horrible idea and 6 wheel drive is much better, it is simply because that teams design and method of construction may have been flawed.
and also in the case of lego, most tires you would want to use have flat surfaces. the rubber lego tread has a taper (is that what you call it?) on the sides, so it will turn better on carpet but on hard surfaces will not help the tread stay flat to the floor. the some lego tires are wide too. which have more scrub when turning so helps keep the robot move in a straight line.
Unread 30-11-2004, 18:31
crazykid234's Avatar
crazykid234 crazykid234 is offline
Techincal assist
AKA: Brian Clegg
FRC #1646 (Precision Guessworks), Alumni FRC #234 (Cyber Blue)
crazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to behold
This year team 234 used the tank design mostly because it allowed us to fly over the six in. steps. again, the game dictates the design.
Don't see the world as it is and ask why; see the world as it could be and ask, why not? - unknown author
Unread 30-11-2004, 18:54
President, VEX Robotics, Inc.
All you tank tread lovers, educate me on the following things:
1. Show me the math that shows tank treads have better pushing force (traction) than a wheeled design.
2. While doing number 1, assume whatever tread material you use for the tank tread can be wrapped around a wheel.
3. Leaving the obstacles out of the equation (stairs, ramps, etc.), why do certain vehicles have tank tread designs (tanks, excavators, snow mobiles, etc.)?
4. Again, leaving obstacles out of the equation; what advantages are there for FIRST robots to use treads? If you say pushing force, or traction; then prove it with math/physics.
I look forward to the range of answers.
Unread 30-11-2004, 19:19
artic_raven's Avatar
artic_raven artic_raven is offline
artic_raven is an unknown quantity at this point
Send a message via AIM to artic_raven
Question Re: Has 6 wheeled designs surpased tank treads
i have a question about the idlers. about how much lower should the idlers be so that they keep a high efficiency but also don't draw all the current?
Unread 30-11-2004, 19:58
AKA: Ken Colton
FRC #0527
Well, this depends on the material of the wheel mainly. If you are using solid rubber wheels, then you only need to lower them a very very small distance, just to take pressure off the outer wheels. If you are using pneumatic tires, the amount that you need to lower them is greater because they will squish down under the weight of the robot. This is just a general rule, the actually distance depends greatly on the individual robot with its many factors, such as weight distribution about the robot, where the idler is located on the robot, etc.
There is also a sort of balance between current and controllability. If you lower the middle wheel a lot, then you will maximize current saving, but you may encounter problems such as your robot drifting from one side to another, or teetering back and forth (which can be annoying). But if you don't lower them enough and all 6 wheel are touching the ground but pressure is off a set of them, you will eat up current trying to turn but you will have more controllability. So, I guess its best to experiment with your design to come up with what your team is comfortable with.
FIRST Volunteer
kcolton@gmail.com
Tank Treads dddriveman Kit & Additional Hardware 27 06-05-2004 18:16
Major problems with tank tread drive Lord Nerdlinger Technical Discussion 13 23-02-2004 21:15
tank treads vs. threaded wheels lj8758 Technical Discussion 14 24-01-2003 00:30
TANK TREADS...welp. archiver 2001 13 23-06-2002 22:50
