Go to Post It worked in CAD. - ey206208 [more]
Unread 30-11-2004, 20:56
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
pic: Version 1.1
Unread 30-11-2004, 20:57
Re: pic: Version 1.1
Looks good Arefin.
Now keep improving and between you and Greg Perkins, I believe we will have 2 great new transmission innovators in FIRST
Unread 30-11-2004, 21:08
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
Thumbs up Re: pic: Version 1.1
Hey Arefin,
It looks very good, I can tell you have worked hard in it and it would be interisting to see every modification that you make to improve it.
Good Luck
Unread 30-11-2004, 21:20
Michael Leicht's Avatar
Michael Leicht Michael Leicht is offline
Drive Coach
FRC #1403 (Cougar Robotics)
Michael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond repute
Arefin nice job on the gear box. now how is inventor? just so proud of you. first you could not get inventor now you can, good job.
Team 303 (2003-2007)-Student-Won FIRST Scholarship to Daniel Webster College
Team 42 (2007-2008)-College Mentor
Team 2342(2008-2011)-College Mentor
Team 1403 (2011- )- Mentor
Unread 30-11-2004, 21:25
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
okay. awesome arefin. great job working with inventor.
now for the Critiquing...
i question the sheer size of this gearbox and the long skinny standoffs holding the plates together. the CIM is a 300 watt motor Perfectly capable of bending, breaking and shearing aluminum with its torque. secondly i suggest some machining to remove material from those gears, i say this not from a weight standpoint but rather from an inertial standpoint. a robot traveling in one direction at full throttle having to slam it into reverse or turn would benefit from less inerta in its gear train simply because its easier, more efficient and takes less time and energy to reverse the direction of a 4oz gear then an 16oz gear. the mass of your gears along with the skimpiness of your standoffs is a deadly combination. also removing the hubs making speed holes and using key ways, or if you don't have a broach witch is most of us try using one of the various locktite products for binding rotational parts together. the stuff works great and it doesn't take much work to use it. i would also suggest that instead of using the clevis's for mounting the cylender i would suggest you drill a hole in your plate and use the threads of the cylender as a bolt and lock it on with some 5/8-18 nuts that would also then act like an extra standoff for you. On the happy side, i like how simple your shifting is. just slide the gear easy right? well, make shure you chamfer the edges of the gears that are meshing into each other to keep them from grinding when you shift. Well, thats my twoCents.
Unread 30-11-2004, 21:33
AKA: Ari
thanks everyone...
thanks tytus for your input... i will consider all of your suggestions. i did think about the sheering problem. but seems to be i solved it (Thanks to JVN). Also thanks to greg for giving me his inputs for this transmission... this is only version 1.1, this transmission will be modified a lot of times.
and tom... greg is way smarter than i am. i have to learn a lot to get there...
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
Hey man, it looks great!
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
Unread 30-11-2004, 21:35
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Arefin,
Have you considered the problem of the center gear grinding against the bottom gear? It seems to me that if you're sliding two moving gears along each other, you could potentially have a problem with grinding of the teeth.
EDIT: I saw you referred to the "sheering problem". Is this what you meant?
Jeff Waegelin
Unread 30-11-2004, 21:37
AKA: Ari
Yes jeff.. thats exactly what i meant... thanks for your input...
Unread 30-11-2004, 21:55
El Jefe de 148
So what did you do to solve said problem? I'm just curious.
Jeff Waegelin
Unread 30-11-2004, 22:00
AKA: Ari
Using 20 dp gears and space each shafts out with the pitch diameter also added another space of .003...
Unread 30-11-2004, 22:08
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
There is probably room in the gearbox to shift ratios so that the shifting gears are spinning faster with less torque. Specifically, increase the size of the CIM pinion, then increase the final stage ratio.
I assume this is all 20 pitch? As I'm sure you know, make sure to buy the strongest material that you can find the shifting gears in.
A good question that I can't answer is wether extra backlash is a good idea for the shifting gears. More backlash means they will be able to shift faster (less friction, more time to do so), but more backlash also means they are slightly weaker. I'd guess a few thousandths extra is a good idea, but this is definitley a question to ask someone who has built a sliding gear shifting gear box.
Also, where are you purchasing that long gear in the final stage?
Team 1257
Unread 30-11-2004, 22:11
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Spur gear stock... available from SDP-SI, McMaster, etc
2001-2004: Team 100
2006-Present: Team 254
Unread 30-11-2004, 22:16
AKA: Ari
Max, Thanks for your input... yes those are all 20 dp gears... but i am thinking about switching them to 16 dp gears. the shifter works fine. and thanks cory for answering the last question.
Edit - Also there will be holes in each gear just not to reduce weight but for what tytus pointed out (look at his post above). Each gear will be anodized.
EDIT- didnt want to post again... so here i go replying to alex from 469. yes i am considering what tytus has said. Also (if you see in the description of the picture) i am planning on moving the motor between the two plates. if i leave it like that i will sure mount it on the chassis somehow to make it stronger. thanks for your inputs.
Unread 30-11-2004, 22:18
Alex Golec Alex Golec is offline
FRC Advocate
no team (FiM Volunteer)
Alex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond repute
Structurally, the position of the CIM motor just sticking out on a sheet of (I'm guessing) about 1/4 aluminum just seems like a hazard to me... but then again I have little engineering knowledge to judge this by. Also, as Tytus mentioned, I think the extra material from the gears needs to be removed and the pieces holding the plates together should be a little bit thicker.
Arefin, Great job on the drawing; it looks great!
_Alex
Linux and new microcontollers. djcapelis Programming 48 29-01-2005 00:26
pic: pic 1 CD47-Bot Robot Showcase 6 22-02-2004 00:29
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
Q&A Watcher Available for Download Nate Smith General Forum 11 19-12-2002 11:12
