Go to Post Every match they would leave blue and red skid marks all over the carpet. It was like someone roadkilled a Smurf. - Koko Ed [more]
Unread 01-12-2004, 01:37
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
Re: Electrical Tips for Rookies
Also: (I had a math teacher do this!)
In math, black is for numbers greater than zero, or positive, and red is for numbers less than zero, or negative. DON'T CONFUSE MATH AND ELECTRONICS!!! LOTS OF SMOKE AND BAD SMELLS!!
Red is ALWAYS positive in electical systems, and you should color-code your wiring correspondingly. Black,or sometimes green, but mostly black, is Negative (actually ground, but it's easier to think of it as negative sometimes)
White is signal, and, unless you use other sensors, that's it.
I had a math teacher try to jump a car. Melted his battery, he did.
Sparks
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
Unread 01-12-2004, 11:15
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
As Sparks mentioned, in a FIRST robot, red is alway positive and black is always ground. In the past there have been rules governing this, and there probably will be again this year.
Anybody who has worked on a robot will tell you that the wiring can quickly become a mess and make things difficult to tell what's what. Something that we do (and I know other teams have done) is color code everything with colored tape. For example, if we choose green for a certain motor, we'll put green tape on everything that connects the RC to the motor. You will see tape in the following places
* RC pwm output
* PWM cable on both ends and in the middle
* Fan on top of speed controller
* Both wires coming out of speed controller to motor
* Motor itself
You will also see the same tape on all power paths to the speed controller
* Breaker panel
* Breaker
* Red/Black wires at both ends
This allows us to quickly determine which wires go where in the case that we have to get in there and work on things. Its a lot easier to ask somebody to trace the green wire than try and describe a certain red wire. We use part STD-C-ND available from Digikey. It's a little pricey, but well worth it. I've also seen some teams use labels from a labelmaker and stickers (I seem to remember Scooby Doo stickers )
Unread 01-12-2004, 11:58
'lil Gach's Avatar
'lil Gach 'lil Gach is offline
Electrical girl
AKA: Tiffany
'lil Gach is a jewel in the rough'lil Gach is a jewel in the rough'lil Gach is a jewel in the rough
Send a message via AIM to 'lil Gach
O yes wiring can become in our electrical team's words a "rats nest"... I work on electrical last year and I wasnt sure that it was going to be hard to find a way to organize the wires... WOW I was wrong.. It became a mess very fast... So we did find a way to organize like Scheck said... Our color coding is very helpful to me too.. As long as we remember what colors go are what..
Unread 01-12-2004, 13:59
I had a math teacher try to jump a car. Melted his battery, he did. Sparks
Sparks,
I don't want to make a big deal here but so people don't get confused I need to say these few things.
For First robots, the rules state the use of red for wires connected to battery positive and black for wires connected to battery negative. This is a convention for most electronic wiring but other colors are used all the time by designers. Measure first to be sure.
The term "ground" is sometimes used for "signal common" or power supply common but the term implies that somewhere the signal common is actually attached to ground. In AC power distribution this wire is green or green with a yellow stripe and it must connect to a rod or pipe in the ground. Ground may or may not be the power negative terminal. No connection between battery and robot frame are allowed even though many electronic systems will "ground" the common point to the frame.
Although Red and Black wires are used for power wiring and motors on First robots, the red and black wires between the speed controllers and motors can actually be tied opposite the convention depending on the direction of the speed controller or Spike. Again always measure, you may find 12 volts when measuring between a motor black lead and the battery black lead.
Other colors are used all the time and the only way to be sure is to check with the manufacturer, wire vendor or by measuring.
Unread 03-12-2004, 12:08
Oh, By the way, black is the wire color for the "hot" in 120 volt AC house wiring. In three phase power systems, black wire is used very often for all phases with some kind of indicator as to which phase the wire represents. Black is also commonly the wire color of both sides of 220 volt house input wiring.
Red in house wiring is commonly used for "switched" power wiring or for anything the electrician chooses. When pulling in multiple circuits in a single conduit or raceway, different circuit "hots" will use a combination of colors (i.e.black, blue, red, yellow, etc.) with white as the neutral and green as ground.
Color codes vary across the country and municipalities so even the above colors may not apply in all locations.
Any Tips on Fundraising? Zzyzx Chit-Chat 3 06-10-2004 15:31
New Robot Electrical Parts Al Skierkiewicz Electrical 13 25-04-2004 18:44
Looking for team 217 Electrical mikey1126 Electrical 15 21-04-2004 22:10
Lots of Electrical Questions Allison K Electrical 18 18-02-2004 11:49
How does your team organize its electrical supplies? Josh Hambright Electrical 8 28-11-2002 13:01
