Go to Post It means Dave Lavery isn't on the Game Design Committee this year. If he were, you probably would have found a banana instead. - Alan Anderson [more]
Unread 01-12-2004, 11:33
Macdaddy549 Macdaddy549 is offline
Mr. Mac
#0549 (DevilDawgs)
Macdaddy549 is infamous around these partsMacdaddy549 is infamous around these partsMacdaddy549 is infamous around these partsMacdaddy549 is infamous around these partsMacdaddy549 is infamous around these partsMacdaddy549 is infamous around these parts
how to design sprockets
Does anyone have an easy way of designing sprockets? We do'nt have the skill in designing them. Is there any software that we might aquire to help with designing? We have the CNC equipment to cut them.
Unread 01-12-2004, 11:40
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: how to design sprockets
You may be able to use the i-sprocket model on www.firstcadlibrary.com but I'm not sure if it is good enough to machine from (to make an accurate working sprocket). Perhaps Ed Sparks will stumble across this thread and let us know, or you could personally contact him.
Unread 01-12-2004, 12:32
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
If you write more about why you'd like to design your own sprockets, we can also make suggestions for other solutions that are probably a bit more practical.
--Madison--
...down at the Ozdust!
Unread 01-12-2004, 12:38
Electrical Engineer
Rookie Year: 1995
In 11 years, we have only made sprockets twice. It was back in the day when the KOP was much more restrictive than it is now. You can buy sprockets so inexpensively, I can not imagine a reason to make your own.
Mike Betts
As easy as 355/113...
Unread 01-12-2004, 12:43
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I seem to remember Team 173 saying that they made sprockets on their CNC machine, either for themselves, or to sell for a profit. Perhaps one of them could elaborate.
I also seem to recall reading/seeing/hearing that the i-part models of gears and sprockets are not good enough to use to cut sprockets or gears.
2001-2004: Team 100
2006-Present: Team 254
Unread 01-12-2004, 12:55
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Last year I used http://www.cadregister.com/ and searched for "sprocket" then you'll see Madison sprocket in the list, then I used type A plate, 3/8 pitch. Then pick the tooth quantity you need from their list and download the CAD file. This file will only have 1 tooth showing so you need to array that tooth around the number of teeth you picked, they should all match perfectly. We had these patterns blown out by waterjet, and then had to bevel the outside edges of the teeth to get them to fit in the chain right. If you just stick the sprocket in the chain without the beveling you'll find the chain will only mesh with 1/2 the teeth then ride out on top of the rest. So that last step is important.
I also made a point to make a variety of sizes in the event I needed to change any ratios after the fact.
Unread 01-12-2004, 13:41
JulieB's Avatar
JulieB JulieB is offline
well........
AKA: Just Julie!
FRC #0538
JulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of light
Send a message via MSN to JulieB
i would just use a ruler and design on the cnc mill it would take that long.
Unread 01-12-2004, 13:54
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
I'm just curious why it is you need to machine your own sprockets. As it was said above, sprockets are so innexpensive, that I can not see the need to spend the time making them in the shop. (other than to say that you made the sprockets yourself - Something I might do - even though it is impractical).
"Jack of all trades, master of none, though offtimes better than master of one".
Unread 01-12-2004, 13:58
Cory's Avatar
AKA: Cory McBride
If you've got the CNC machine, the only cost to you is the cost of the raw materials.
2001-2004: Team 100
Unread 01-12-2004, 14:51
Swampdude's Avatar
AKA: Dan Quiggle
For us last year, we had 2 very good reasons. The weight - since light weight sprockets in 3/8 pitch are going to be hard to find and not necessarily have the interior (shaft) shape we need.
The mounting configuration we needed was unique. So we ended up with an extremely light and strong, custom made sprocket that fit the design perfectly in the end.
As long as we have the waterjet as a resource, I plan to make sprockets. Sprockets are a great place to save weight. For example, we had (4) 60 tooth sprockets that would have weighed 2.8 lbs ea. (in steel) x 4 = 11.2 lbs
but the custom high strength aluminum ones weighed around .7lbs x 4 = 2.8 lbs - 8.4lb savings!
Unread 01-12-2004, 15:21
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
This is what we did on our CNC this year.
We choose the chain size.
Measured the chain spacings and such
Calculated how many teeth we wanted on the sprockets.
Got some plate aluminum.
We then figured out how far the teeth/holes needed to be apart. Calculus....
Made a G code program.
Once we got the code ready we took a drill bit slightly bigger than the chain "hooks" or whatever you call them. The machine then drilled a series of spaced holes all the way around the plate of aluminum. We then placed a mill bit in the machine and machined half of the holes away.
Here are some pics of our arm's gears:
http://www.tigertrons.com/Pictures/2...n/100_0596.JPG
http://www.tigertrons.com/Pictures/2...n/100_0710.JPG
http://www.tigertrons.com/Pictures/2...n/100_0716.JPG
These worked great for us. We also made some 50 tooth sprockets for #35 chain in our drive train
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 01-12-2004, 16:05
SpaceOsc's Avatar
SpaceOsc SpaceOsc is offline
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
SpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant future
Send a message via AIM to SpaceOsc Send a message via Yahoo to SpaceOsc
Talking Re: how to design sprockets
how well did they do with the chain? did it slip any? was there a harsh destruction of metal noise? and how much did it weight?
2014-2017: Team 4501 Coach/Lead Mentor
2002-2011: Team 702, Mentor
2001-2002: Team 702 Captain
Unread 01-12-2004, 16:18
AKA: Bradley Rigdon
They did great with chain. No slipping or anything. We did have a little side wear on the drivetrain due to misaligned sprockets/chain. We have been through 10 competitions with these sprockets and they are still working.
I do not have an exact weight, but I think they weighed half as much as the steel sprockets!
You do not need any fancy programing to make a sprocket work.
Just a simple program, CNC mill, mill bit, and a drill bit!
Unread 01-12-2004, 16:30
KathieK's Avatar Unsung FIRST Hero
KathieK KathieK is offline
Sometimes FIRST makes my head hurt!
KathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond repute
Send a message via AIM to KathieK
[quote=Cory]I seem to remember Team 173 saying that they made sprockets on their CNC machine, either for themselves, or to sell for a profit. Perhaps one of them could elaborate.[quote]
I'm sure that one of our CNC Committee members can elaborate. But yes, we make our own aluminum sprockets - CNC Software (producers of MasterCam Software) is one of our sponsors!
You are not that far from us - perhaps a field trip is in order?
Check out my 2016 Conference presentation, Dumpster Diving: How to Get Stuff for Your Team for Free or at Little Cost
www.usfirst.org | www.nefirst.org | www.firstnemo.org
Helping mentors since 2004
Unread 01-12-2004, 16:55
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
The machinerys handbook has all the ANSI Sprocket Tooth Forms for roller chain sprockets. It also has all the neccesary information for flange thickness and tooth section profile dimensions.
It is not super complicated to create a sprocket. Sit down with the tooth form and profile information and you should be able to make a CAD/CAM drawing fairly quickly.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
[Official 2005 Game Design] OK, so YOU design the 2005 game... dlavery FRC Game Design 37 26-10-2004 23:15
On Game Design Matt Leese General Forum 38 30-04-2004 19:08
Design Sharing Rod General Forum 32 14-01-2004 22:00
How do you design your robot? Gui Cavalcanti General Forum 23 16-11-2003 18:33
Ok, so YOU design the 2003 game... dlavery General Forum 157 07-01-2003 23:55
