Go to Post Welcome to FIRST! It's in your blood now... - AmyPrib [more]
Unread 01-12-2004, 17:14
stephenthe1 stephenthe1 is offline
stephenthe1 is on a distinguished road
Cool pwm outputs vs. joystick y-axis
hello ,
ok, I'm kinda a newbie. for simplicity's sake, lets say I have a robot with a single motor, and all I want it to do is go forward and backward. is there a way to make the robot adjust its speed according to how far the joystick is pushed forward or backward? rather than just when it reaches full forward or reverse. can you show me what the code would look like? if that isn't possible, or easily done, can you send me what the code would look like to control the power going to the motor via a pwm. that would be super helpful because with that I can figure out most of the other stuff.
oh, and if you happen to know, how do I read from a shaft encoder that's hooked up to a digital input.
thank you so much,
Stephen
Unread 01-12-2004, 17:19
Re: pwm outputs vs. joystick y-axis
pwm01=pwm02= yourJoystick_Y_axis;
Unread 01-12-2004, 17:24
Talking Re: pwm outputs vs. joystick y-axis
sweet. now does anyone know what the code for a shaft encoder would look like?
Unread 01-12-2004, 17:26
check out Kevin Watson's example code for using encoders. It is full of comments and very helpful. Or, just search around these forums, you are guaranteed to find what you are looking for
Unread 01-12-2004, 17:29
Lightbulb Re: pwm outputs vs. joystick y-axis
thanks
Inverting Y axis on joystick FormatteD_C Programming 7 24-02-2004 16:56
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
Trouble with pwm outputs misterikkit Programming 16 17-01-2004 10:56
relay and pwm outputs nick_champ_2 Electrical 1 31-01-2003 13:08
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
