Go to Post As Alice once said: "Curiouser and curiouser!" - Mike Betts [more]
Unread 21-11-2004, 14:25
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
RoboEmu2(code simulator)--now with C!
Well, its only been a year since I said I was going to do this, but hey, better late than never, right?
Anyways, it's finally here (in at least pre-beta form): RoboEmu2 -- now with C! I've tested it with the default code and everything seems to work fine, but given that I haven't been involved with a team for 2 years now, that's about the only code I've tested it with.
Thus, as always, I'm asking for everybody's help: please download RoboEmu2 and try it with your code. If it doesn't work, please email me your code and any warnings/errors you get.
In any event: enjoy, comment, criticize, etc:
www.robbayer.com/re2.shtml
Edit: for those of you who don't know, RoboEmu is an emulator for the control system. Back in the days of PBASIC it was used as a way to quickly test new code and algorithms without needing an actual robot to play with. This new version marks the transition from PBASIC to C, thus supporting the new controllers.
Unread 21-11-2004, 15:18
Re: RoboEmu2(code simulator)--now with C!
Ert, i get the error "Failed to start because QTMTNC321.DLL was not found"
I googled the dll and couldnt find it anywhere.
Unread 21-11-2004, 15:20
Joshua May's Avatar
Joshua May Joshua May is offline
Go Bears!
FRC #1110 (Binary Bulldogs)
Joshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond repute
Send a message via AIM to Joshua May
I got that same error as well.
The FIRST Wiki - openFIRST - Ultimate Robot Challenge - URC Wiki
I currently have 50 GMail invites, PM or email me for one.
UC Berkeley Class of 2009
2005 Las Vegas Regional Autodesk Visualization Award
2005 Las Vegas Regional #8 Seeded Alliance with 988 and 1505
2006 Southern California Regional #15 seed
Unread 21-11-2004, 15:25
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
ditto, but I did find something on google: http://www.google.com/search?q=qtmtnc321.dll&sourceid=mozilla-search&start=0&start=0&ie=utf-8&oe=utf-8&client=firefox-a&rls=org.mozilla:en-USfficial
Appears to be some library that is part of "Qt" which sounds like a tool that you might have used to compile this program.
Team 1257
Unread 21-11-2004, 15:42
nathanielreindl's Avatar
nathanielreindl nathanielreindl is offline
Triumphant Return from the Depths
AKA: Fiction
FRC #1451
nathanielreindl is an unknown quantity at this point
Send a message via ICQ to nathanielreindl Send a message via AIM to nathanielreindl Send a message via Yahoo to nathanielreindl
I compiled it from source on Fedora Core 3 against whatever version of kdelibs-devel (read: qt-devel) I happen to have, and it works just fine with the default code provided in the tarball.
When I get a moment or two, I'll make the necessary changes to our existing code and see what happens then.
Unread 21-11-2004, 16:36
My bad... new version now uploaded. Grab it from the website.
-Rob
Unread 21-11-2004, 17:25
Fold em oval!
MiniGW doesn't understand the "short long" type that C18 accepts (24 bit signed integer). I will use long's temporarily, but I wonder if you could add something to the batch file that will convert types because incorrect variable sizes can definitley screw up code.
Team 1257
Unread 21-11-2004, 17:29
Joel J's Avatar
Joel J Joel J is offline
do you..
Wonderful!
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 21-11-2004, 18:51
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
cool stuff....
Unread 01-12-2004, 20:15
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
What kind of magic is behind this, namely how does it work?
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 01-12-2004, 20:34
Umm Errr...
Yes exactly how in depth is the emulation? What are known things that will not work? Is it strictly a C VM or are you doing any emulation at the processor level? I suppose you would have to to run the .lib files.
1139 Alumni
Unread 05-12-2004, 18:42
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
I get the errors
C:\mcc18\EduCode>C:\mingw\bin\mingw32-make.exe re2_win
gcc -o recore.dll -D_ROBOEMU -shared user_routines.c user_routines_fast.c re_hac
k.c re_core.c
In file included from user_routines.c:18:
printf_lib.h:15: warning: conflicting types for built-in function `printf'
user_routines.c: In function `User_Initialization':
user_routines.c:84: `TRISAbits' undeclared (first use in this function)
user_routines.c:84: (Each undeclared identifier is reported only once
user_routines.c:84: for each function it appears in.)
user_routines.c:96: `ADC_2ANA' undeclared (first use in this function)
user_routines.c:102: `TRISFbits' undeclared (first use in this function)
user_routines.c:111: `LATAbits' undeclared (first use in this function)
user_routines.c:112: `LATFbits' undeclared (first use in this function)
user_routines.c:113: `LATHbits' undeclared (first use in this function)
re_core.c: In function `update_outputs':
re_core.c:35: `pwm09' undeclared (first use in this function)
re_core.c:35: (Each undeclared identifier is reported only once
re_core.c:35: for each function it appears in.)
re_core.c:36: `pwm10' undeclared (first use in this function)
re_core.c:37: `pwm11' undeclared (first use in this function)
re_core.c:38: `pwm12' undeclared (first use in this function)
re_core.c:39: `pwm13' undeclared (first use in this function)
re_core.c:40: `pwm14' undeclared (first use in this function)
re_core.c:41: `pwm15' undeclared (first use in this function)
re_core.c:42: `pwm16' undeclared (first use in this function)
re_core.c:44: `relay1_fwd' undeclared (first use in this function)
re_core.c:45: `relay1_rev' undeclared (first use in this function)
re_core.c:46: `relay2_fwd' undeclared (first use in this function)
re_core.c:47: `relay2_rev' undeclared (first use in this function)
re_core.c:48: `relay3_fwd' undeclared (first use in this function)
re_core.c:49: `relay3_rev' undeclared (first use in this function)
re_core.c:50: `relay4_fwd' undeclared (first use in this function)
re_core.c:51: `relay4_rev' undeclared (first use in this function)
re_core.c:52: `relay5_fwd' undeclared (first use in this function)
re_core.c:53: `relay5_rev' undeclared (first use in this function)
re_core.c:54: `relay6_fwd' undeclared (first use in this function)
re_core.c:55: `relay6_rev' undeclared (first use in this function)
re_core.c:56: `relay7_fwd' undeclared (first use in this function)
re_core.c:57: `relay7_rev' undeclared (first use in this function)
re_core.c:58: `relay8_fwd' undeclared (first use in this function)
re_core.c:59: `relay8_rev' undeclared (first use in this function)
re_core.c: In function `update_inputs':
re_core.c:77: `p1_x' undeclared (first use in this function)
re_core.c:78: `p1_y' undeclared (first use in this function)
re_core.c:79: `p1_wheel' undeclared (first use in this function)
re_core.c:80: `p1_aux' undeclared (first use in this function)
re_core.c:81: `p1_sw_trig' undeclared (first use in this function)
re_core.c:82: `p1_sw_top' undeclared (first use in this function)
re_core.c:83: `p1_sw_aux1' undeclared (first use in this function)
re_core.c:84: `p1_sw_aux2' undeclared (first use in this function)
re_core.c:85: `p2_x' undeclared (first use in this function)
re_core.c:86: `p2_y' undeclared (first use in this function)
re_core.c:87: `p2_wheel' undeclared (first use in this function)
re_core.c:88: `p2_aux' undeclared (first use in this function)
re_core.c:89: `p2_sw_trig' undeclared (first use in this function)
re_core.c:90: `p2_sw_top' undeclared (first use in this function)
re_core.c:91: `p2_sw_aux1' undeclared (first use in this function)
re_core.c:92: `p2_sw_aux2' undeclared (first use in this function)
re_core.c:93: `p3_x' undeclared (first use in this function)
re_core.c:94: `p3_y' undeclared (first use in this function)
re_core.c:95: `p3_wheel' undeclared (first use in this function)
re_core.c:96: `p3_aux' undeclared (first use in this function)
re_core.c:97: `p3_sw_trig' undeclared (first use in this function)
re_core.c:98: `p3_sw_top' undeclared (first use in this function)
re_core.c:99: `p3_sw_aux1' undeclared (first use in this function)
re_core.c:100: `p3_sw_aux2' undeclared (first use in this function)
re_core.c:101: `p4_x' undeclared (first use in this function)
re_core.c:102: `p4_y' undeclared (first use in this function)
re_core.c:103: `p4_wheel' undeclared (first use in this function)
re_core.c:104: `p4_aux' undeclared (first use in this function)
re_core.c:105: `p4_sw_trig' undeclared (first use in this function)
re_core.c:106: `p4_sw_top' undeclared (first use in this function)
re_core.c:107: `p4_sw_aux1' undeclared (first use in this function)
re_core.c:108: `p4_sw_aux2' undeclared (first use in this function)
re_core.c:110: `PORTAbits' undeclared (first use in this function)
re_core.c:115: `PORTFbits' undeclared (first use in this function)
re_core.c:126: `rc_dig_in17' undeclared (first use in this function)
re_core.c:127: `rc_dig_in18' undeclared (first use in this function)
re_core.c:133: `competition_mode' undeclared (first use in this function)
C:\mingw\bin\mingw32-make.exe: *** [re2_win] Error 1
C:\mcc18\EduCode>pause
Press any key to continue . . .
Anybody else get this? =/
http://www.mikesorrenti.com/
Unread 05-12-2004, 22:31
Originally Posted by MikeWasHere05
I get the errors...
Are you getting this with the default code, or with code you're compiling yourself. If it's stuff you've made, make sure you #include "re_hack.h".
If that doesn't work, send me an email with your user_routines.c and I'll try to see what's wrong.
-Rob
Unread 05-12-2004, 22:36
As of right now, timers and interrupts don't work and variables of type "short long" won't work. The timers and interrupts thing will be fixed at some point, but I'm really not sure about how to do 3-byte variables on x86.
As for how this thing works, it's actually quite simple. You compile your code into native Windows/Linux/etc as a dynamically loadable module (DLL's in Windows speak). This library file contains a few RE2-specific functions (from recore.c) that the main program uses to interface with your code. The driver program simply calls these functions once ever 26ms (for the slow-loop function) or whenever your computer has free cycles (for the fast-loop function). The majority of the work here is being done by gcc, so anything that's ANSI-C should compile. Whether or not it works as expected depends on whether you're using a PIC-specific feature (timers, interrupts, etc).
-Rob
Unread 15-12-2004, 20:35
doyler doyler is offline
Rookie / Programmer
#0900 (Infinity)
doyler is an unknown quantity at this point
wow, that was awesome, thanks a lot
