Go to Post I've determined that the only thing rumors are good for is putting your knickers in a twist. - JaneYoung [more]
Unread 01-12-2004, 21:19
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Exclamation Registering Inventor 8?
How do you register/authorize Inventor 8 that we got. When I run it and click authorize and click the link to https://register.autodesk.com/ and go through all that, it brings me to a screen for FLEXIm network and asks for Host name and Host ID. I haver no idea what these are for or what they are?
When I try to register it through the program itself (not clicking link), it comes up with an error #20.
What should I do?
Unread 01-12-2004, 21:49
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Registering Inventor 8?
What should I do?
FlexLM is a licence manager server. I was hoping that this wouldn't be necessary, but what it often requires is a network connection to a computer running the FlexLM server service, whenever a workstation tries to access the actual CAD software. Depending on the application, sometimes, you can configure the workstation to act as its own server, but depending on the exact details of the copies of software we received, that may not be possible--and I wouldn't be surprised if the software "phoned home" on its initial use, to mark the licence server as being allocated to a specific MAC address (which is in turn unique--usually--to the network card). Some versions of Pro/E do something similar, and for the same reason, I can't access AutoCAD 2002 on a GM laptop at home, because it isn't connected to a valid domain with the requisite FlexLM server.
In short, I don't know what to do in particular, but that may clear some of it up for you.
Unread 01-12-2004, 21:50
NotaNerd's Avatar
NotaNerd NotaNerd is offline
I am a physics god
AKA: Alex
FRC #1418 (Vae Victus)
NotaNerd will become famous soon enough
It's a very intensive, and laborious process to register all of the new software. Our sponsor has been handling it ( a great man). But from what I understand, you have to call in every copy of the software that you install. That means if you have 20 computers like we do, you have to call in every single one of them. When you call in, they ask for the number and you give it to them. Then they give you a unique code (really really long) that you then enter in. Following that, your software is registered and you're ready to go. I don't know the number, but check the install section of the software of the manual for further details.
Unread 02-12-2004, 15:19
James114's Avatar
James114 James114 is offline
FRC #0114 (Los Altos High School)
James114 is just really niceJames114 is just really niceJames114 is just really niceJames114 is just really niceJames114 is just really nice
Send a message via AIM to James114
I know about calling in every "request code" and if you want to install all four AutoDesk Design Academy programs. Each has its own unique "request code" meaning that there are 104 request codes to call in if you want to register all four products. You would think they would want to make it easy or somthing.
2004 - Drive Train- 2 Awards | 2005 - Drive Train/ Driver/ Team Captian - 3 Awards | 2006 - Mentor- 8 Awards
Unread 02-12-2004, 18:23
MrB's Avatar
MrB MrB is offline
871 Team Leader
AKA: Brian Buonomo
FRC #0871 (WI RoboTechs)
MrB is a jewel in the roughMrB is a jewel in the roughMrB is a jewel in the roughMrB is a jewel in the rough
I know in the past, I have been able to e-mail Autodesk for authorization codes in batches (Autodesk ACES package). Which means you need to install on all machines, copy down the request codes and e-mail them all at once. This is a bit easier than calling each on individually.
I too ran into this problem, but have yet had time to call Autodesk to resolve it.
I'll try to due this tomorrow, its been on my list all week. I'll let you know how we make out.
~ Mr. Buonomo, Team 871
Unread 07-12-2004, 18:58
Daniel_H's Avatar
Daniel_H Daniel_H is offline
FRC #1156 (Under Control)
Daniel_H is just really niceDaniel_H is just really niceDaniel_H is just really niceDaniel_H is just really nice
my doubt comes even before this FLEXIm stuff
should I Install the "single user" option in all the computers of the network and register them 1 by 1 or install by the "network" choice?
I dont know what Host name and Host ID are, we talked to the network admins and they don't know that too.
can anyone help me on that?
I'm lost =(
my e-mail and IM:
zzdanielzz@terra.com.br
thanks
[<o>] gogogo [<o>]
http://undercontrol1156.com/
Unread 09-12-2004, 00:03
Jack's Avatar
Jack Jack is offline
FIRST Scouting Network
AKA: Andrew Schenk
FRC #0201 (The FEDS)
Jack is a jewel in the roughJack is a jewel in the roughJack is a jewel in the rough
Send a message via AIM to Jack
Just email: authcodes@autodesk.com
In the body put:
Hello,
My name is NAME.
The product I have is the Autodesk Design Academy with serial number:
SN-SN.
I am requesting an authorization code for Inventor 8. The request code
is: BLAH
Thank you very much,
NAME
I just copy and past the same email with a different request number for each license i want to authorize. They'll reply within a couple hours (if it's in the middle of the day). I think that's a lot easier than having to copy down that long string off the phone
Jack
Team 201 - 2003 Great Lakes Semifinalists & 2003 Archimedes Division Finalists :|: Webmaster of www.feds201.com -> FBI Scouting
Winner of The 2003 ChiefDelphi Web Award for: User That Started The Most Non Chit Chat Threads
Winner of: 2003 FIRST Ventures with 5451.68 End Points
All about me: http://knehcsa.vze.com
**Check out the New FIRST Scouting Network**
Unread 09-12-2004, 11:24
Daniel_H's Avatar
In the body put:
Hello,
My name is NAME.
SN-SN.
is: BLAH
NAME
Jack
so I must install the "single user license" in each computer of my network?
[<o>] gogogo [<o>]
Unread 09-12-2004, 21:13
Jack's Avatar
AKA: Andrew Schenk
No.. If you're doing a network instillation.. i guess you should be able to the network license thing. But if you're stations don't have distributed applications, you would want to single user license them all.
Also, with regards to what i said yesterday about what you need to include in the email. Autodesk actually wants a little more info. (They accecpted my first two registrations with only the name.. but they wanted more the third time.. go figure.. lol)
Originally Posted by autodesk
USER INFORMATION
Salutation:
First Name:
Last Name:
Phone:
Fax:
Email:
ADDRESS INFORMATION
Company Name:
Address 1:
Address 2:
Address 3:
City:
State/Region/Province:
Zip/Postal Code:
Country:
Company Phone:
Company Fax:
Of course, also be sure to include the Product (Inventor 8), the SN and the Request code.
Jack
Unread 13-12-2004, 15:19
This whitepaper might be helpful as well: http://www.chiefdelphi.com/forums/pa...le&paperid=393
Unread 14-12-2004, 22:34
rmmlg's Avatar
rmmlg rmmlg is offline
#0900 (Infinity)
rmmlg is on a distinguished road
Does FIRST let us do it as a network license or does it have to be 25 individual licenses. Anyway, I had to authorize everything this year by e-mail since the automatic registration didn't work for any of the software, but the e-mail went without a hitch and a response usually came within a few hours.
Ryan
Team 900 (Infinity)
