Go to Post pit visitor: "Why'd you use #35 chain?" team member "less links to CAD...." - Aren_Hill [more]
Unread 01-12-2004, 22:32
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Re: Cylinder mock-ups of gears in Inventor?
There are some great gear models at www.firstcadlibrary.com or www.cbliss.com, but I've found out that it's just simpler to represent gears as cylinders using their pitch diameters - this allows inventor to run faster if you have a slower machine. Our first year of using inventor, we modeled everything down to the gear teeth and even the slots on the 8020. In the end, our model approached 1.5 GB and normally would take 10 minutes to load in - if the computer didn't crash first.
Unread 01-12-2004, 23:09
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Another tip, stack two cylinders on top of each other. one with the pitch diameter and one with the outside diameter of the gear. that way you can still check for interferences with other parts. The formulae:
OD = (N+2)/DP
PD = N/DP
OD = outside diameter
N = number of teeth
DP = Diametral Pitch
PD = Pitch Diameter
Looking for gears from BostonGear in Inventor.. geo Inventor 6 05-08-2004 10:07
Gears in Inventor Joshua May Inventor 12 01-07-2004 23:32
Need Inventor model 3/4" Bore Cylinder Quick sanddrag Inventor 1 05-04-2004 00:40
Stopping a Piston... Dan 550 Technical Discussion 7 02-02-2002 11:36
How do i make gears in inventor? mnkysp6353 Inventor 1 16-01-2002 02:31
