Go to Post 50 years from now, the FRC will still be waiting and hoping for a water game. That's my prediction. - TheBoulderite [more]
Unread 02-12-2004, 22:41
stephenthe1 stephenthe1 is offline
stephenthe1 is on a distinguished road
Post shaft encoder help
hi, I don't know if anyone is having the same problem, but the white paper on using shaft encoders is a little above my level. if you'r Kevin Watson, is it possible you could write a tutorial or explain your code in a simplified form. this thread could be a nice place to explain it. if anyone can help that would be wonderful. any basic knowledge at all would be awesome.
Unread 03-12-2004, 10:33
Electrical Engineer
Rookie Year: 1995
Re: shaft encoder help
Steve,
Please be a bit more specific. Are you asking how an encoder works or how Mr. Watson's code works. If the latter, is there a specific area in the code that needs explanation...
Mike
Mike Betts
As easy as 355/113...
Unread 03-12-2004, 16:09
Jaine Perotti Jaine Perotti is offline
...misses her old team.
AKA: BurningQuestion
FRC #0716 (The Who'sCTEKS)
Jaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond repute
Send a message via AIM to Jaine Perotti Send a message via MSN to Jaine Perotti Send a message via Yahoo to Jaine Perotti
I would suggest reading the white paper "Interrupts for Dummies".
This will explain ALOT about how the code for encoders works -- specifically interrupts, which are probably the best way to count distance. (Also read the Quadrature Encoder white paper).
Here are some threads that may also help you with basic knowledge:
Choosing an Encoder for the Drive-Train
Optical Sensors Used as Encoders
Mechanical Wheel Encoders
Hope this helps!
Florida Institute of Technology
Ocean Engineering, '12
Choosing an Encoder for the Drive-train MikeDubreuil Electrical 11 21-10-2004 00:50
pic: 571's new gearz loose weight CD47-Bot Robot Showcase 24 16-04-2004 16:35
Wiring "3-pin" Shaft Encoder. Joel J Programming 7 27-02-2004 17:21
how to add steps in the provided encoder program for the edu Zaramel2002 Programming 3 11-02-2004 08:35
Problem with 5/8 in. shaft in this years kit echos Kit & Additional Hardware 5 14-01-2004 21:21
