Go to Post An innovative strategy based off of good scouting beats a #1 alliance any day. - rufu5 [more]
Unread 02-12-2004, 23:14
Re: Neat & Organised Electric Wiring
If you haven't done so check out the picture Steve links to above. In addition to starting out very neat, all of the power devices are fairly close together. This keep wire runs short (more power to the motors) and has less weight than spreading them all over. (Steve, I may like to use your photo as demo example. Would that be OK?)
Venkatesh, I think you mean #10, that is the minimum wire size for most of the motors and power to speed controllers. #10 Zip cord, colored red and black, is available in spools from Newark. It is fairly flexible, easily routed through mechanical stuff and quick to terminate. Follow Venkatesh's advice for soldering all crimped connectors. I know it sounds like suspenders and a belt but you can't play if you don't work.
Color coding is easy with 3m EIA colored tape, available from Digikey. This comes in rolls of ten colors, I think 3-5 yards of each. We wrap each wire from power distro to speed controller, from speed controller to motor, PWM cable, circuit breaker and CB location. position on RC and spike or victor. With one glance you can see which PWM cable on which RC output feeds which speed control or spike which in turn feeds which motor and know which circuit breaker to pull to disable the circuit or which one to put back when you have removed them for troubleshooting.
Unread 02-12-2004, 23:52
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Use finely stranded wire so you can get nice contours and bends. In particular, I've always thought that the 6 gauge wire provided in the kit is absolutely aweful because it is not finely stranded at all and is very stiff. Spend the money to get some nicer wire (less resistance too)
Also, those sticky backed zip tie "mounts" will come in handy for securing wires.
Last, wire wrap of some sort often (available at auto parts store or maybe hardware store) does a nice job of tidying up things and works great in a situation like a flexible joint of an arm. The stuff is black plastic tube with a slit down one side.
Unread 03-12-2004, 00:15
D.J. Fluck
Posts: n/a
Even though this isnt a neatness issue, this is very important too, make sure you use the correct sized wire for each particu
From the 2004 game FIRST Checklist (Check new rules for updates to this, obviously)
Originally Posted by Rule 5.2.6-R21
5.2.7.1-R44
#6 wire from battery (+ and -) to Anderson Disconnect and to
main circuit breaker, junction blocks and circuit breaker
panels
Originally Posted by Rule 5.2.7.1-R45
#10 wire minimum from breaker panel to speed controllers
for CIM, Drill, van door, Globe, and F-P motors.
Originally Posted by Rule 5.2.7.1-R47
5.2.7.1-R49
#16 wire minimum to Robot Controller power, solenoid
valves, window motors, relay modules, compressor, large
muffin fan.
Originally Posted by Rule 5.2.7.1-R48
#24 wire minimum from switches, PWM cables, sensors,
potentiometers, small muffin fans, custom circuits, and
LED’s.
Unread 03-12-2004, 11:15
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Yes, I am glad we can be of help. If I can get a pic of our wiring I will post it here.
We do not stop playing because we grow old;
we grow old because we stop playing.
1047 Amazing wiring Lord Nerdlinger Robot Showcase 1 27-02-2004 18:28
Help wiring Line sensors magical hands Electrical 1 18-02-2004 10:17
