Go to Post So, FIRST is turning into the For the Inspiration of Science and Trains? That makes sense... Not a whole lot of re-branding will be needed.... - dqmot17 [more]
Unread 02-12-2004, 19:43
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
Neat & Organised Electric Wiring
Hello,
One of the projects that we are doing in the Pre-Season, is to make our electric wiring neater and more organised. Last year was our second and because we used 6 motors(4 for the gearbox, 2 for the arm & hook) and 8 spikes the wiring looked very tangled. Althought we had the wiring out of the way it didnt look very nice, it was hard to access and hard to identify. Also the 3-pin wires from the controllers were labeled, but still when they were all zip-tied together it was very hard to replace or change a wire(all our wires were labeled). Other than organising we crimp,solder and heat shrink our connectors and make sure that our electrical is safe.
So my request to all the great teams here is that please let me know about different toold & products you might use to make ur electrical neater(wire clips, snap-on connectors,labeling products e.t.c)
Thankyou,
Team 1219
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Unread 02-12-2004, 20:50
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Re: Neat & Organised Electric Wiring
For the time I've been on my team, we never really had neat and organized wires. During 2004 we attempted to nicely sort out the wires, but later we ripped all the organized wires while hastily trying to repair our drivetrain....
but anyways, I remember seeing 968's robot with their very neat wiring: http://www.chiefdelphi.com/forums/pi...gle&picid=6476
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 02-12-2004, 20:58
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
From much personal experience,
1) Use 12 gauge wiring liberally. The 12 gauge wire is very easy to keep track of, is very flexible, gives you excellent current characteristics, and is rather forgiving of bends/kinks.
2) Use "relay farms". A relay farm is a piece of plexiglass with holes drilled out for up to six relays each. Then six relays are mounted. Use one on each side of the robot. This way, you have spare relays on board (we usually have 1 spare per farm) and can remove all the relays on a side at once.
3) Do the same as above for Speed controllers. However do not keep spare speed controllers on the robot - they are too easily damaged there - but have holes drilled out for them.
4) Use color-coded stickes on each wire pair (+ and -) for a device. NOTE DOWN WHAT COLORS ARE CONNECTED TO WHAT DEVICE! DO NOT LOSE THAT PIECE OF PAPER! (I speak from experience; I have lost wire-color maps twice, they are a pain to reconstruct)
5) Crimp the ends of connectors very very well. Then solder them. You can never have a strong enough joint.
6) Do not ziptie wires together in a bundle unless you have a very good reason to do so. In general, do not overuse zipties. Use velcro loops instead, as they are far more easily removed.
7) Make sure the battery connector is easily accessible. You never know how quickly you will have to change it.
8) Have a diagram of all the wiring on the robot. This diagram should, preferrably, be locatable at critical times during build season and in the pits.
And lastly, good luck at being neat. =)
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 02-12-2004, 21:06
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Layout is very important, Here is a link to how we laid out out Victors, wiring block etc
http://www.swarren.ca/Build2004photo.../IMG_0820.html
I didn't have a pic of our final wiring but what we did was channel all of our wires. The direct route is not always the neatest. Take your time, plan ahead and pretend that it is art. If you do, not only will it be neat but easier to follow. If you would like to come visit us let me know.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 02-12-2004, 23:14
If you haven't done so check out the picture Steve links to above. In addition to starting out very neat, all of the power devices are fairly close together. This keep wire runs short (more power to the motors) and has less weight than spreading them all over. (Steve, I may like to use your photo as demo example. Would that be OK?)
Venkatesh, I think you mean #10, that is the minimum wire size for most of the motors and power to speed controllers. #10 Zip cord, colored red and black, is available in spools from Newark. It is fairly flexible, easily routed through mechanical stuff and quick to terminate. Follow Venkatesh's advice for soldering all crimped connectors. I know it sounds like suspenders and a belt but you can't play if you don't work.
Color coding is easy with 3m EIA colored tape, available from Digikey. This comes in rolls of ten colors, I think 3-5 yards of each. We wrap each wire from power distro to speed controller, from speed controller to motor, PWM cable, circuit breaker and CB location. position on RC and spike or victor. With one glance you can see which PWM cable on which RC output feeds which speed control or spike which in turn feeds which motor and know which circuit breaker to pull to disable the circuit or which one to put back when you have removed them for troubleshooting.
Unread 02-12-2004, 23:52
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Use finely stranded wire so you can get nice contours and bends. In particular, I've always thought that the 6 gauge wire provided in the kit is absolutely aweful because it is not finely stranded at all and is very stiff. Spend the money to get some nicer wire (less resistance too)
Also, those sticky backed zip tie "mounts" will come in handy for securing wires.
Last, wire wrap of some sort often (available at auto parts store or maybe hardware store) does a nice job of tidying up things and works great in a situation like a flexible joint of an arm. The stuff is black plastic tube with a slit down one side.
Unread 03-12-2004, 00:15
D.J. Fluck
Posts: n/a
Even though this isnt a neatness issue, this is very important too, make sure you use the correct sized wire for each particu
From the 2004 game FIRST Checklist (Check new rules for updates to this, obviously)
Originally Posted by Rule 5.2.6-R21
5.2.7.1-R44
#6 wire from battery (+ and -) to Anderson Disconnect and to
main circuit breaker, junction blocks and circuit breaker
panels
Originally Posted by Rule 5.2.7.1-R45
#10 wire minimum from breaker panel to speed controllers
for CIM, Drill, van door, Globe, and F-P motors.
Originally Posted by Rule 5.2.7.1-R47
5.2.7.1-R49
#16 wire minimum to Robot Controller power, solenoid
valves, window motors, relay modules, compressor, large
muffin fan.
Originally Posted by Rule 5.2.7.1-R48
#24 wire minimum from switches, PWM cables, sensors,
potentiometers, small muffin fans, custom circuits, and
LED’s.
Unread 03-12-2004, 11:15
Grow Up? Why?
Yes, I am glad we can be of help. If I can get a pic of our wiring I will post it here.
Unread 03-12-2004, 12:41
Woodie Flowers Award
Ken Patton Ken Patton is offline
purple
FRC #0051 (Wings of Fire)
Ken Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond repute
Some good guidelines here, but I have a few questions for you guru's:
1. Why do you say to use velcro instead of zipties? Seems to me there would be less stress on the wire bundle to just snip off a ziptie than there would be to try and rip the velcro.
2. What brands of super-flexible wire are you using? (I know Paul Copioli and 217 have used this stuff on their well-organized wiring jobs - they are my benchmark for great wiring).
3. Aren't you supposed to solder the end BEFORE crimping? This is called tinning I believe.
One idea that we have used the last few years: rather than hard mount the polycarbonate control-mounting-board to the robot, we have "suspended" it trampoline style from the frame. Seems to me that this is lighter and it provides some amount of isolation from the vibration of the robot.
Ken
Unread 03-12-2004, 12:51
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
No! You should never tin wires before crimping because you won't get good pressure distribution inside the crimp and it will loosen over time. If you use good quality crimp connectors, sized exactly for the wire gauge, crimped with the right tooling, the connection will be as good as it gets (without soldering). Because there are so many "ifs" in that, soldering after crimping is recommended for most other cases!
Pete Kieselbach
Unread 03-12-2004, 13:00
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Here are some of the boards we're looking at for inspiration in 2005:
258's 2003 board is pretty cool.
http://www.seadawgs.com/Pictures/200...d/Img_0820.jpg
http://www.seadawgs.com/Pictures/200...d/Img_0821.jpg
Note the way the RC mounts over the Spikes (which require no ventilation)... slick!
Also 968's 2004 board. (That entire robot is a work of ART. So neat, so organized. I wish we could be like this!):
http://www.chiefdelphi.com/forums/sh...ad.php?t=25672
I wish I had more pics of that one.
And... my favorite, Team 71's control board:
http://www.team229.org/photo/single/2441
http://www.chiefdelphi.com/forums/pictures.php?s=&action=single&picid=7159&direction =DESC&sort=date&perrow=5&trows=10&quiet=Verbose
You can't really see it in these pictures but...
Basically they're entire control board is mounted on thin lexan. They then suspend this sheet from their robot frame. (As an outside wall of the robot).
I wish I had a good picture of their 2004 board. It makes me feel like our control board is waaaaay overweight...
Though, knowing our luck...
If we tried the Beatty method -- another robot would probably stick their arm through it or something every match.
Unread 03-12-2004, 13:33
Bill Gold Bill Gold is offline
Retired -- 2006
Bill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond repute
When I saw the title of this thread the last thing I expected was for one of my robots to be mentioned, much less alongside the likes of the mighty Travis Covington's superior wiring techniques. Thankfully John was just brining up a little trick we used that year, and other teams have done as well. Seriously, Travis’ wiring always drops my jaw. It’s something that we all should aspire to wire like.
Unread 03-12-2004, 15:09
Ken
Ken,
There are several companies that make velcro just for wire management. I think it is OK for static loads but I question it's use on movable objects like our robots. The load on a large wire bundle during a hit is likely to open.
Newark sells a #10 zip cord that is not super flex but is more flexible than most off the shelf #10. It is designed for automotive stereo install and has a red and black wire.
A great connection is one that is mechanically stable first. Any connection that will be soldered should be crimped tight first. We use a equivalent to the Anderson connector for #10 connections (to make it easy to change) to motors. We add push on 1/4" connectors for speed controllers. (The same as are on the circuit breaker panels.) All of these connectors start out as uninsulated. We crimp the wire then solder and add a piece of heatshrink over the wire and connector to protect it, the contacts for the Andersons must not have exposed wire after contact insertion. Never "tin" wires before a crimp contact as explained above.
Adding a poly plate to mount everything just adds too much weight for us. I am under STRICT guidelines for weight restrictions. (wink, wink)
Unread 03-12-2004, 19:59
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
Hi!
I really can't talk too much (our robot's wiring job was TERRIBLE!!!) but here's some good ideas.
1) Use plugs. If you use, say, a Molex connector, then if you have to pull a component or even an entire board, you just disconnect it. My team is after me to modularize the entire electronics board, so this seems like a reasonable idea. It is, however, one more thing to go wrong.
2) SOLDER WHENEVER POSSIBLE!!!! I really don't care if you have crimp fetishes or only have crimps or if you have already crimped a wire. Crimps fail much more often than solder jobs. (Last year for our main connector to the battery, we used crimps tightened down in a vice, then we heated it with a blowtorch and put lots of solder on it. Worked like a charm, and looked cool too.)
3) Never, and I mean never, put a wire under stress and expect it not to come out. If you have a 12" gap and an 11" wire, then go get yourself a 13" wire, dangit! Vibrations can wear through wires, pinch sections can cut wires, and tension can pull your connectors right out. USE A LONGER WIRE THAN WHAT SEEMS REASONABLE! it may weigh more, but it will work.
Neatness and orgainization is a very valuable thing to have on a robot. It streamlines repairs, diagnostics, and makes the robot look good. And your team will love you for it.
Sparks
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
Unread 04-12-2004, 08:57
Matt Reiland's Avatar
'The' drive behind the drive
Ken
1.The Velcro/Zpties debate has went around quite a bit in the manufacturing environment for the plants. We used to see tons of zip ties on the robot and tool dress, some of them waaaay to tight causing a failure point. We then moved on to rubber straps that had some give and were reusable. However we found that people put them on way to tight just like the zip ties and the rubber broke down VERY fast and failed. So the current method is both, but take care not to pull with all your might which can cut into the insulation on the wires, I like things to be 'snug'
2.For wire I recommend Deans wet noodle , it is hard to find in 10ga though.
http://www.robotcombat.com/marketplace_wire.html
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
1047 Amazing wiring Lord Nerdlinger Robot Showcase 1 27-02-2004 18:28
Help wiring Line sensors magical hands Electrical 1 18-02-2004 10:17
