Go to Post "You know, a robotics regional is the only place where you can walk in and see two people in chicken suits and not be confused." - Herodotus [more]
Unread 05-12-2004, 15:31
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
CAD on a Mac
Is there any good CAD software that will run on a mac? Or howabout under Virtual PC? Thanks.
Unread 05-12-2004, 16:05
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
Re: CAD on a Mac
Look at http://www.architosh.com/
It has all of the CAD packages available for the mac. Basically Mac has a good selection of modeling tools, but doesn't have Autodesk products nor Solidworks. Autodesk was promising Autocad and Inventor to the mac, but that was 2 years ago and I haven't heard anything since.
Vectorworks seems to be the most popular choice these days for macs.
Rhode Warriors
NAVSEA/Raytheon/URI/Middletown, Portsmouth, Tiverton, Mt. Hope HS
Quality Robots Since 1996
Unread 05-12-2004, 16:31
MrToast's Avatar
MrToast MrToast is offline
I named Greg Needel's cat!
AKA: Dave DeLong
no team (Rhode Warriors)
MrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud of
Send a message via AIM to MrToast
Re: CAD on a Mac
One day when I get enough money and also a computer that can run it, I'll be buying the VectorWorks suite:
VectorWorks 11
HTH,
Dave
(#121, 2004) Archimedes semi-finalists with 237 and 386! I had an awesome time guys, and thanks for the hat!
(#121, 2004) BC5 semi-finalists with 190 and 1027! Awesome time! We went further than I thought we could! Thanks for all your help w/ our transmission!
(#121, 2005) Galileo quarter-finalists with 47 and 203! Thanks for all your support through the stress!
If it moves and it shouldn't, use duct tape.
If it doesn't move and it should, use WD-40
"It'll all work out in the end, and if it doesn't, it's not the end." - Jeff Bullock
Unread 05-12-2004, 19:54
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Re: CAD on a Mac
The only professional CAD software for the Mac that I'm aware of is from Ashlar. They were pioneers in parametric design and I've used their 3D drafting software for about 10 years, first with Ashlar Vellum and now with Graphite. Their current offerings are Mac OSX and Windows native. Unfortunately, their prices are larger than their following and I think Cobalt, their solids package, costs about the same as Inventor.
I have Graphite (a 3D wireframe app) loaded on my Tibook, though I use Inventor on my desktop PC. I use Graphite to sketch concepts for work and FIRST as well as for home construction plans, but Inventor is a much better application for engineering design.
File import and export are a little dodgy with Ashlar - I can generally export dxf and iges successfully, but they've never put much effort into their import functions.
Ashlar's programs are extremely easy to learn and use effectively, but they've never really made it into the majors, though according to Ashlar, "The Scaled Composites design team confirmed that they designed the majority of SpaceShipOne and its companion aircraft, White Knight, in Cobalt." Rutan has figured heavily in their ad campaigns over the years.
Pete Kieselbach
Unread 06-12-2004, 04:30
Mr. Ivey's Avatar
Mr. Ivey Mr. Ivey is offline
Mark Ivey
AKA: Mark
Mr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of light
Send a message via AIM to Mr. Ivey
Re: CAD on a Mac
For quick and easy work all the way up to exact detailed work I use SketchUp 4.1, it's awsome. I find it to be a better suit for me than some of the big CAD programs on the PC. It's easy to learn, and you can draw just about anything with it. Although it does have it's limitations in the fact you can setup a drawing like you could in Inventor or AutoCad. But it is a good tool none the less. The web address is http://www.sketchup.com/ and it has loads of movies and tutorials to help you get started. You can get the 8 hour trial version for free, and for students the cost is $99. I would recomend taking a look at it.
ivey
When you tell a student not to do it, you shouldn't do it. Or else you will wind up with a 3/8" drill bit in your finger... Like I did...
Unread 06-12-2004, 07:31
Re: CAD on a Mac
Sanddrag,
You have a lot of answers here, but I wanted to add a history lesson. Autocad was written for both platforms at one time. Autodesk stopped supporting the Mac platform because their customer base was moving towards PCs due to their ease of use on large networks, support for multiple monitors and other peripherals like graphics tablets and big plotters. Big businesses need standardization and although Apple did have some of this same support, it was not enough to attract the big customers. I think the last version was Release 9.
Unread 18-11-2005, 00:30
Re: CAD on a Mac
Does anyone know if Inventor will run under VirtualPC or is it just something that will not happen anytime anywhere? If it does work, how bad is it? See the thing is, we have a whole lab full of G4s available for our use right in our build space, so, it would be nice if we could Inventor on them.
Unread 18-11-2005, 07:38
GET IT ON!!
Re: CAD on a Mac
Unfortunately it is not going to happen even if you had a quad g5. Inventor is a very processor and GPU intensive suite. Virtual PC only emulates a very basic video card that won't suite it. That is why Virtual PC can't emulate games.
You might be able to start it up, but it won't be useable in any sense and will probably crash.
Rhode Warriors
Unread 18-11-2005, 07:51
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
Re: CAD on a Mac
im sure some older releases of inventor like Inventor 5 might work. IF i remember correctly they kept using mroe and more memory as the newer versions were released.
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 18-11-2005, 09:17
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
Re: CAD on a Mac
I run Inventor 3 on Virtual PC 7 occasionally, and it is usable, though slow.
Virtual PC is just as stable as a real Windows PC...I've never had any trouble with it at all. It's a little slow, but it gets the job done
Unread 19-11-2005, 10:57
Bill Moore's Avatar
Bill Moore Bill Moore is offline
Iv2gr8sons
AKA: Be More
FRC #0365 (Miracle Workerz)
Team Role: Team Spirit / Cheering
Bill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond repute
Send a message via AIM to Bill Moore
Re: CAD on a Mac
Hey Sandrag! I believe that you are out of luck here. I tried to do the same with 3dsMax version 4 back in 2001, and I tweaked every setting I could on both sides of Virtual PC and the best I could get was that the program would open, but just wouldn't run. (That was under the old Mac OS 9 on a 333Mhz Blueberry iMac.)
You may have better options once the Mac converts to Intel chips, especially with the Wine and Darwine initiatives. But that's a few years off, so it doesn't help now. (BTW: did you ever score a co-processor?)
Originally Posted by Al Sierkiewicz
Sanddrag,
Al, this is a history of many Mac applications, and is certainly not restricted to CAD. But if you are suggesting that Sanddrag switch platforms to conform to what "big business" does, I disagree. First off, not everyone is going to work for a big business with a phlegmatic IT department, as you and I do. Most are going to work at smaller or mid-sized businesses, and they need to be adaptable to whatever that business uses. Today, businesses are using Windows, Linux, Unix and Mac, adaptability to more than one of these systems can seriously increase your chances of being employed. People need to learn how to "operate" the computer, not just press the keys and click the mouse -- a fact that almost everyone ignores as they focus on an OS battle that has long since ended.
In 1999, I was providing volunteer computer support to a local school, when a parent came up and lamented how he thought the school should change to PC's. He was worried that when his daughter entered the workforce, she would not be readily employable since she only knew how to use a Mac. His daughter was in fourth grade. I wanted to ask him, "So, if your daughter learns to drive in a Chevrolet, she'll never be able to drive a Toyota cause the buttons and knobs are in different positions?" I didn't press the SmartA** button that day, instead, I tried to explain to him that computer OS's of 1999 were not going to be anything like computer OS's when his daughter graduates from college. She will have to relearn as they change over the next 12 years. I wasn't successful in my explanation, so I shut up and let him enjoy his misery.
In my job, I still run computers using DOS and Windows 95 in my lab, and my main computer is running Win98 (not Second Edition). I occasionally use Unix and mainframe applications as well. I assist my boss with his Win2000 machine and other folks running XP. At home I use Mac OS X and OS 9 (mainly to still use Pagemaker). Oh, and my job has nothing to do with IT or IT Support, it's polymer research; my formal computer training consists of 1 FORTRAN programming class punching out cards to be fed into a mainframe.
Adaptability is the key folks. Your job will not be the same 10 years from now (when I retire), or 20 years or 30 years from now. The tools and systems you use will change, and you must be able to adapt along with them. That is the key to making yourself marketable over the long term.
Three Signs You Are Getting Old: 1) You forget things, 2) You begin repeating yourself, 3) You forget things.
Unread 19-11-2005, 14:01
petek's Avatar
What would Dave do?
Re: CAD on a Mac
If you want to run any Windows OS program as hardware-intensive as Inventor, I think you'll have better luck dual-booting these machines (rumored to be introduced in January). Though I suspect that you'll have to wait until Apple releases high-end Intel desktop machines to get it to run properly.
I couldn't agree more! I've found that my work has undergone major changes about every 3 to 5 years. I started out doing analog circuit development and data acquisition and 30 yrs later I'm doing lab automation, process development for pharmaceutical research and (mostly) project management and paperwork.
BTW, my first desktop PC was a Mac IIcx (with dual monitors), which I used for CAD (MacDraft, Claris CAD and Ashlar Vellum). I didn't have a Windows box on my desk until about 6 yrs ago, though I used them a lot for machine control before that. However, once I got the opportunity to switch to Inventor (at v5.0), I quickly abandoned the Mac for CAD, though I still use it for most other things. Ironically, a PC-centric design engineer I work with has been oogling my 3-yr old TiBook - amazed at how well it handles sleep and power management, and how easy the screen is on the eyes compared with PC displays.
Pete Kieselbach
Unread 19-11-2005, 19:27
Greg McCoy's Avatar
boiler up!
Re: CAD on a Mac
Seeing how Microsoft currently has Virtual PC for PowerPC Macs and Virtual PC for running a Windows OS inside of an x86 Windows machine, I suspect they will release Virtual PC for Intel Macs as well. If not, it won't take long for Darwine to do the same thing. I really wouldn't want to have to take down OS X to run Windows.
2006 should be an great year for Apple...
Unread 21-11-2005, 07:54
Re: CAD on a Mac
Bill,
I fight this battle everyday with the host of applications that are available in broadcasting. Unfortunately, this is an end user battle. It is not what platform is best, it is what platform will produce the best return for our software development. Autodesk supported both platforms at one time (a long time ago) but found that there was not the return in sales for the Mac software. So the question still remains as to which platform one should choose based on CAD software (Autodesk), database apps, dedicated control software, etc. For Autodesk products that is a Windows based OS. We do have a variety of Mac machines here running primarily graphics generation software. This is not because the Macs are better at it (an argument for a different day) but simply because the software is written for Mac OS. Those in the graphics world know that artists prefer the Mac (and therefore a significant customer base already exists) and so target that market. Many of the apps that were traditionally Mac based are now written for both platforms. Photoshop (Adobe family) is one of these and Protools (audio workstation) is another. However, even Protools is sliding in the Mac forum and support for raid editing systems is not available to Mac users at the present time.
At the recent Inventor training I attended, the instructor told us that applications are migrating to the intensive use of video cards and a future (1-2 years) "hot" setup will use dual monitors driven by video cards costing up to $10K or $15K each. Again those developers may choose to support only Windows users and Mac people will be left out in the cold.
Unread 21-11-2005, 13:08
GET IT ON!!
Re: CAD on a Mac
http://www.hardmac.com/news/2005-11-20/#4756
It seems some people already ported WINE to MAC OS X, which is good.
Crosssover, which is a better WINE, has already promised a Mac OS X version when the first x86s versions come out.
Rhode Warriors
CAD on your team? SpaceOsc Inventor 25 18-11-2004 11:14
CAD Portfolio? Madison Career 9 20-10-2004 12:45
First Logo as a CAD file jrgrim12 Inventor 4 14-02-2003 11:42
CAD Drawings? archiver 1999 17 23-06-2002 22:35
Macintosh CAD??? Suneet General Forum 7 02-02-2002 10:43
