Go to Post The size, speed, and power of full sized FRC robots are much more sublime. People go to the zoo to see the lions and tigers, not the ants. - Jared Russell [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 01-12-2004, 07:53
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
PHP file system stuff
Couple 'o php questions.
  • How can I tell what files/folders are in a directory?
  • How can I tell if a file exists without making two calls to fopen()? (assuming I then want to open it for read)
Unread 01-12-2004, 09:22
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
Re: PHP file system stuff
1) scandir()
2) file_exists()
Brandon Martus
e-mail
Unread 05-12-2004, 14:46
Programming User
So, I'm trying to remove a directory here...
Windows XP system running Apache 2.0.50 with PHP 4.3.9. (Yes, I know that 2.0.52 is out. Upgrade is coming soon.) I'm trying to remove a directory which is located relative to the current one at ../pages/<dir>. I'm able to delete all the files in the directory, but on trying to remove the directory itself I get a "Permission denied" error.
Here's the exact code which applies:
PHP Code:
// Ensure the directory only contains the struct file (and the current and parent dir references)
if(!(count(scandir("$dir/pages/$_POST[cat]")) <= 3))
header('Location: /index.php?section=admin&page=failure');
            die();
// Remove struct file
if(file_exists("$dir/pages/$_POST[cat]/struct") && !unlink("$dir/pages/$_POST[cat]/struct"))
            die();
// Remove the directory
if(!rmdir("$dir/pages/$_POST[cat]"))
            die();
The struct file is just a file which is used by other parts of the site to maintain the directory structure. (The entire site is just a pre-alpha type thing for learning PHP and eventually some of the code will go into our team's site. The main thing is a user can login and edit content pages over the web.) The struct file does get deleted successfully; I see it disappear in my little Windows Explorer window. $dir contains a path which is brings the path back to the root of the site before going deeper in. In this case, it equals "./..". (The reason for the ./ at the beginning is how I generated it. I was too lazy to remove that part of it, as it shouldn't make a difference. Does it?)
I'm using pretty much the ship configuration which is in the php.ini-dist.recommended (or whatever that file was called) file.
Ideas? Was I unclear?
Unread 06-12-2004, 07:36
Programming User
And maybe this is related:
Using the code below (I had something in a different file, but I wrote this stuff out just for testing. I get the same results with both things.) I get... nothing. The page just appears again without the slightest hint it did anything. Actually, on the other one, I have more error checking and it catches that the move_uploaded_file() fails and reports it appropriately.
Here's the test code:
PHP Code:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<title>Untitled Document</title>
</head>
<body>
<?php
if(isset($_POST['image']))
        echo
$_FILES['image']['tmp_name'];
move_uploaded_file($_FILES['image']['tmp_name'], "./$_POST[name]");
        echo
"<img src='./$_POST[name]' />";
        echo
"<img src='./$_FILES[image][tmp_name]' />";
<form method="post" action="test.php" enctype="multipart/form-data">
<table>
    <tr>
        <td>File:</td>
        <td><input type="file" name="image" /><input type="hidden" name="MAX_FILE_SIZE" value="40000" /></td>
    </tr>
    <tr>
        <td>Save as:</td>
        <td><input type="text" name="name" /></td>
    </tr>
</table>
<input type="submit" value="Upload" />
</form>
</body>
</html>
--EDIT--
Acutally, after adding the enctype="multipart/form-data" to the form, I now get nothing. It just reloads.
What do you wish you knew about the new control system? Joe Ross Control System 2 09-01-2004 21:47
openFIRST switches debugging system to Bugzilla Timothy D. Ginn FIRST-related Organizations 0 28-12-2003 00:32
Need a FIRST Robotics control system kershawrobotics General Forum 3 07-07-2003 09:49
Current Monitoring system questions PyroPhin Technical Discussion 44 17-02-2003 15:34
who can we buy stuff from?!?! archiver 2001 7 23-06-2002 23:04
