Go to Post Its never too early to start dreaming. - Robert Cawthon [more]
Unread 06-12-2004, 15:56
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Carbon Fiber Bicycle Fabrication
Not really a FIRST related tech question but I wanted to troll for an answer from some fellow engineers.
I'm looking at a new road bike. Here is what I'm looking at. http://www.specialized.com/SBCBkMode...h rjcg.j27010
I wanted to see if any of you know how Specialized eliminated the bonding lug style construction, i.e. Trek & Giant. I can't figure it out. They claim monocoque construction but I can only figure out how to make this frame in 3 pieces and bond them together. 1 for the main triangle and 1 for each seatstay/chainstay.
Thanks in advance,
Pete
Unread 06-12-2004, 17:07
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Re: Carbon Fiber Bicycle Fabrication
Does monocoque neccesarily mean one complete bike frame? I know that alot of bike manufacturers label their frame as monocoque construction but is really two monoqoque pieces welded together (as far as the aluminum mountain frames go that I am aware of) The seam runs right down the top of the top tube, bottom of the down tube, etc. I'm sure you have seen these frames. The Intense M1 and Tazer FS, Tomac, etc, are good examples
As far as a monocoque carbon frame is concerned, unless there is some sort of lost material in the frame voids, I cannot come up with an answer either.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 06-12-2004, 22:54
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
ditto to what Travis said. there are some carbon fiber bike makers that do that, but, i'm not sure if Specialized is one of them.
But, if their bikes truly are one-piece monocoque, then they may do it using foam core injection. from what i understand, the foam serves the same purpose as a bladder would.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 06-12-2004, 23:36
PMGRACER's Avatar
PMGRACER PMGRACER is offline
AKA: PAUL GIANNOSA
PMGRACER is on a distinguished road
Been a while since I've been in the Bicycle bus, but 15 years ago Kestrel made a Monocoque style Carbon Fiber Frame. They in fact did use a bladder and foam. That manufacturing method didn't produce a reliable wall thickness as the resin would not flow evenly. That is why Trek originally developed the OCLV design which had the reinforced lugs. I think currently Trek still uses that style of Manufacture but the Head tube, seat stay/ bottom bracket and chainstays are moled as one piece units and straight tubes are bonded to them.
Racing is an incurable addiction!!
Unread 07-12-2004, 07:40
PMGRACER
Was that an RTM process over the bladder?
The only thing I could come up with was a foam core process but there is frequently discussion of hollow tubes. I couldn't figure out how they would due a lost foam process.
Thanks for the answers everyone.
Unread 07-12-2004, 18:31
PMGRACER's Avatar
AKA: PAUL GIANNOSA
I don't remember what the actual process was. As far as I know, Kestrel isn't building frames anymore. Also, I don't have much experience with Carbon Fiber molding techniques. Sorry I can't be of much help there.
Carbon fiber edomus General Forum 4 19-02-2004 19:02
Carbon Fiber For Your Project Racingjeff General Forum 10 03-06-2003 14:08
Q&A Discuss: Carbon Fiber CD47-Bot Extra Discussion 1 04-02-2003 12:15
Carbon Fiber kbmeister Kit & Additional Hardware 6 07-01-2003 12:24
Carbon fiber? Munchausen Technical Discussion 1 25-01-2002 21:20
