Re: c debugger
Originally Posted by stephenthe1
this is quite rediculous. first should atleast have microchip create a simple debugger. even one that simply checked for spelling errors (ex. c is case sensitive) and find missing semicolons and brackets. it shouldn't be that hard for them to also make it check potential values for variables to see if the value would be out of the variable's bounds. First needs to "modern-up" a little. I mean, have you seen visual studio 2003 or 2005? It needn't be as complex as visual studio, just have some of the same features. regular c isn't nearly as complicated for the purpose of programming the robots.
Steve,
Just hold on a second... Have you even tried MPLAB? It already does everything you outline except for potential variable values (and it even does a bit of that).
It will even run your code in simulation with full watch variable and breakpoints. Do a search in last years fori and you will find a few discussions on the subject.
What you guys were originally talking about was what is called an in-circuit-emulator. That is what Dave was referring to when he said you would have to get access to the chip.
Regards,
Mike Betts
As easy as 355/113...
