Go to Post I believe you have the right to develope your own opinion. I would suggest it be based on actual experience and facts. - Mike Copioli [more]
Unread 09-12-2004, 13:27
Electrical Engineer
Rookie Year: 1995
Re: c debugger
I would be tempted to make it:
  relay1_fwd = p1_sw_trig;
  relay1_rev = p2_sw_trig;
  relay2_fwd = p1_sw_trig;
  relay2_rev = p2_sw_trig;
And tell the operators that if they push both buttons, nothing happens.
Once again, to all I apologize for momentarily losing it earlier...
Mike Betts
As easy as 355/113...
Unread 09-12-2004, 14:49
Electrical Engineer
Rookie Year: 1995
Re: c debugger
Originally Posted by Mike Betts
...It will even run your code in simulation with full watch variable and breakpoints. Do a search in last years fori and you will find a few discussions on the subject...
I did a quick search and found the excellent post by the Wizard from last year:Simulator Post.
Read his post and the help file for MPLAB SIM and you should be off and running...
Mike Betts
Debugger and Simulation in new IDE? authgeek1218 Programming 1 08-12-2003 18:39
