Go to Post "Fair and professional" needs to be two-directional. - John Neun [more]
Unread 09-12-2004, 16:05
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Re: encoder vs. motor
Originally Posted by stephenthe1
can you look at this and tell me if you see any errors.
	//the encoder is at 50 resolution
	//the arm motor is attatched to pwm_02
	//the encoder is attatched to rc_dig_in06
	unsigned int encoder;
	if (p2_sw_trig == 1)
	pwm_02 = 220;
	if (rc_dig_in06 == 1)
	encoder = encoder + 1;
	if (encoder == 11)
	pwm_02 = 128;
You only want to increment the encoder variable when rc_dig_in06 goes from 0-1 or from 1-0 (pick one). So you need to keep track of the previous value and the current value, then increment only when when it changes.
[OCCRA]: motor brush springs greencactus3 OCCRA Q&A 1 28-09-2004 20:56
Multiple Motors phrontist Motors 12 21-06-2004 23:05
Mounting the drill motor Veselin Kolev Motors 11 26-04-2004 14:27
WHich motor to lift and for arm thoughtful Motors 8 25-02-2004 10:34
Thermal Protection archiver 2000 1 23-06-2002 23:27
