Go to Post wait a minute...Dave posted a hint here yesterday. but no one has tried to analyze it word by word. has something changed since the kickoff??? - jerry w [more]
Unread 09-12-2004, 17:23
J15.5h's Avatar
J15.5h J15.5h is offline
#1247 (ROKS)
J15.5h is an unknown quantity at this point
Question GETTING AWAY FROM THOSE WALLS?
When using a track drive or a SKID-STEER type steering system, how would you move away from the wall if you got pushed side ways against it accidentally?
- J15.5h (TEAM 1247 ROKS)
Unread 09-12-2004, 17:36
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
Re: GETTING AWAY FROM THOSE WALLS?
The trick is to believe it's possible.
...Only a few people are awake and they live in a state of constant total amazement. -JP Shanley, Joe vs. the Volcano
Unread 09-12-2004, 17:48
mgreenley
Posts: n/a
As a prelude to this post, for the sake of fully explaining myself, I am going go into more detail than needed, but I will bold objects that are most important to the topic at hand.
When using a tank drive (equivalent to a track drive for this purpose), there are a few options of movement. You can move Left Drive(L) Forwards (F) or Backwards (B) as well as not moving (N). This also applies to the Right Drive(R). This means that you can have these senarios:
LF RF =forwards
LF RN =curve clockwise to the right with your R as the pivot point
LF RB =turn clockwise with a point between the drives as the pivot point
LN RF =curve counter-clockwise to the left with your L as the pivot point
LN RN =stopped
LN RB =curve clockwise to the right with your L as the pivot point
LB RF =turn counter-clockwise with a point between the drives as the pivot point
LB RN =curve counter-clockwise to the right with your R as the pivot point
LB RB =backwards
This is the list of basic movements for a tank-drive robot non-inclusive of speeds (varying PWM values or gear ratios) and also non-inclusive of choosing between sharp braking or glide-braking with your victor's.
The four options bolded above allow the robot to move away from a wall that one side parallel to it's drivetrain direction is pressed flat up against. This is because the robot drags around the turn and thus means that your pivot point becomes the upper or lower point of contact with the side of the field instead. That is the theoretical easiest way out. In reality, all FIRST robots motors (drill, CIM, fisher-price, van-door, window, etc...) are powerful enough to push the robot out in any of the turning configurations barring another robot pinning you there.
I hope this answers your question for you, but I've been doing History for an hour (Civil War), so I may be making a few mistakes. Correct at will.
Unread 09-12-2004, 18:10
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
It's actually not hard, you just drive away from the wall. The way the robots are built, they almost always have more than enough power to push themselves away from the wall, so long as your drivers know what they're doing. The most important thing for this is to just make sure your batteries are fully charged, so your robot has plenty of power to push itself away from the wall, as this (along with pushing other robots) is probably one of the more power intensive aspects of a match.
AIM --> Woloi
Email --> ian@woloschin.com
Unread 09-12-2004, 23:09
occra 23.
AKA: ryo
None #1481
and then of course assuming 1) you have lots and lots of torque. 2) you have plenty of grip to spare. 3) the walls are not bolted into the floor every foot.
then the walls will move. or at least give a little if you are missing either 1) or 2) or maybe both. so you basically dont have to worry about getting stuck at all
*edit. oh right. you are pushed sideways into the wall. nvm 2) then well aaaanyways, the REAL question is if you have 2wd but have the drivewheels at the center point of your robot. either you need a lot of torque qith grip or just less grip. either way, unless your robot is a circle, center 2wd is probably the hardest to get away from a "parallel park to the wall"
Unread 10-12-2004, 07:17
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
My team used BreckoFlex tracks this year and had NO problem. Its relativley easy, say your up agains the player station wall. you can drive straigh with a slight arc and eventually you will have gotten off the wall. OR you can simply just turn left or right and it will "flop" around... i use the term "flop" as it does this weird turn i cant explain.
WARNING....
we used and offset idler pully in our tracks....so we had less of a foot print to turn on...
I HIGHLY RECOMMEND USING A OFFSET IDLER OR RISK THE POTENTIAL OF NOT TURNING...WE FOUND OUT THE HARD WAY!
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 10-12-2004, 16:13
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
WARNING....
To also include on this we actually also had a nub on the side of teh frame toowhich allowed use to have a slight turn on the wall...enough so that we can get off it...it kinda looks like whats below
This allows you to pivot on that point
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
Soundproofing Sam Oldak Technical Discussion 15 04-04-2004 00:20
Low Cost Field BOM Andy Brockway General Forum 161 11-01-2004 08:34
Atlanta - activities/ammenities I'd like to see KathieK Championship Event 57 03-08-2003 00:57
Plexi-Glass walls Brett W Rules/Strategy 8 21-02-2003 22:44
FIRST themed rooms David Kelly General Forum 50 06-07-2001 11:11
