Go to Post Overall, I thought FIRST did a great job with the rules this year - very simple and very clear for the most part. However, something is always going to fall through the cracks (and I don't mean that in a bad way - people need to know that it's practically impossible to do something perfectly). - Chris Hibner [more]
Unread 09-12-2004, 20:32
Re: Electromagnet
Mike,
In checking the IFI site, the controller is designed to feed "mini solenoids" on the six solenoid outputs. Each output is TTL level and can sink 85 ma. If you were to find a miniature relay designed for 5 volts and less than 85ma coil current you could use it to control the current to a magnet structure. The source for the magnet would need to be external to the controller (so as not to draw excessive currents.) and the relay contacts need to be able to handle whatever current the electro magnet requires.
Unread 09-12-2004, 20:42
AKA: Dr. Brooks
no team (WRRF)
Re: Electromagnet
Mouser part number 653-G6E-134P-DC5 should do it,
the coil is designed for 5 volts, and the relay drive
current is 40 ma. We selected this one to drive
transistors for a programmable battery load tester.
The spdt relay handles 3 amps.
If you need to control a bigger current,
use this relay to actuate a bigger one.
Originally Posted by Al Skierkiewicz
Mike,
Unread 09-12-2004, 20:45
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
Re: Electromagnet
Mike,
I was checking that too. If a you could make a switch that was controlled by PWM, the PWM ports are designed to take up to 4 amps. By that time, though, it would be easier to just to go with a relay.
Just food for thought.
Sparks
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
