Go to Post Set your goals as high as your team thinks they can achieve (drafted, drafting, win awards, regional champs, world champs, etc) and go for them. Let the chips fall and have no regrets. - BPetry234 [more]
Unread 10-12-2004, 08:33
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
Re: Check out 701s shifting tranny..
Good luck with your transmission (both in design, and function). In the years that I've been doing this, I have always been involved with the "drive & chassis" in some way. Last year it was by building the transmission, and this year I did design a transmission (and a few variants of it). but a few weeks ago we stumbled across this nice 4 speed automatic, and I'm working up a prototype of that (it had 4 speeds, but I have an idea for adding a high low range). So, the driver can choose between normal range,and a lower range for some more pushing power. It would be similar to a tractor. Giving it in effect, 8 different gear ratio's. Stick with drive and chassis, and keep working on designs. Also, whenever you get the chance to do some of the machining, do it, it's a great thing to know. I myself have been the lead machinist student on the team, as said above last year I build the tranny's, and then I also designed, and built the winch. I go to school for mechanical engineering, but all my free time (what little I have) you can find me in the machine shops.
Good Luck, I look forward to seeing you design come to life.
"Jack of all trades, master of none, though offtimes better than master of one".
Is a shifting transmission really necessary? Jay TenBrink Technical Discussion 78 02-08-2005 09:21
Team 48 Tranny Info Travis Hoffman Chit-Chat 5 04-07-2004 17:38
3 shifting transmission... Arefin Bari Technical Discussion 19 04-03-2004 01:24
Team 968's technokat inspired 4 speed tranny Travis Covington Robot Showcase 12 01-03-2004 10:06
WDW Park Hopper Passes-How to check joe_balint General Forum 19 21-05-2002 16:28
