Go to Post A good engineer will never stop learning. From his peers, technicians, and competitors. The field is just to vast for any one person to know it all. - Mr. Mike [more]
Unread 10-12-2004, 16:13
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
Re: GETTING AWAY FROM THOSE WALLS?
Originally Posted by Greg Perkins
My team used BreckoFlex tracks this year and had NO problem. Its relativley easy, say your up agains the player station wall. you can drive straigh with a slight arc and eventually you will have gotten off the wall. OR you can simply just turn left or right and it will "flop" around... i use the term "flop" as it does this weird turn i cant explain.
WARNING....
we used and offset idler pully in our tracks....so we had less of a foot print to turn on...
I HIGHLY RECOMMEND USING A OFFSET IDLER OR RISK THE POTENTIAL OF NOT TURNING...WE FOUND OUT THE HARD WAY!
To also include on this we actually also had a nub on the side of teh frame toowhich allowed use to have a slight turn on the wall...enough so that we can get off it...it kinda looks like whats below
This allows you to pivot on that point
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
Soundproofing Sam Oldak Technical Discussion 15 04-04-2004 00:20
Low Cost Field BOM Andy Brockway General Forum 161 11-01-2004 08:34
Atlanta - activities/ammenities I'd like to see KathieK Championship Event 57 03-08-2003 00:57
Plexi-Glass walls Brett W Rules/Strategy 8 21-02-2003 22:44
FIRST themed rooms David Kelly General Forum 50 06-07-2001 11:11
