Go to Post Count up all the white space in your code sometime and calculate how much weight it adds. - ChuckDickerson [more]
Unread 11-12-2004, 16:20
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
CAD/CAM softwear
I recently got the CAD/CAM softwear called BobCad. It allows for you to open drawings of other softwear and drop a part into a CNC, and machine it throught computer. It would be pretty useful if it worked.
The problem is that the softwear doesnt support *.dwg files, which are the files that Inventor and AutoCad use for drawings. Does anyone know of a way to convert *.dwg files to another format?
Thanks
Unread 11-12-2004, 16:24
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: CAD/CAM softwear
AutoCad/Inventor can save files into a number of different formats, one of which is surely compatible with your software (if it isn't, your software is junk). Just click File | Export... (at least in AutoCad) and select the filetype you wish to use.
Team 1257
Unread 11-12-2004, 20:17
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Perhaps look into the IGES, STP and DXF file types.
Unread 11-12-2004, 23:17
Ah yes. That certainly helps. Thanks guys!
on a side note, does anyone else have BobCad? If so, how do you use it? (not literally, I mean what do you do, use its built in CAD or drop in drawings, if so from what softwear)
