Go to Post Congratulations to team 341, your work is nothing short of what I want to do when I grow up. - kjolana1124 [more]
Unread 12-12-2004, 10:03
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: Has any team or anybody made a 80% - 100% lexan bot?
Originally Posted by ahecht
Yes, but other aluminums don't fare as well. 5052 aluminum, for example, has ratios between 70 and 100. Other aluminums range from a ratio of 17 to a ratio of 237.
6061 is definitley the most commonly available (and probably one of the cheapest) types of aluminum used structurally. Most of the aluminum extrusion kits, and most of the tubing/angle/channel found on FIRST robots is 6061.
Additionally, Polycarbonate varies (you'd have to go to some other brand than Lexan) and glass filled PCs have ratios around about 80. I'm pretty sure glass filled PC is too hard and brittle for most framing use.
Team 1257
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
How do you organize your team? NoodleKnight Team Organization 18 03-11-2005 22:57
Thank a Team with an i-Pod !!! OZ_341 General Forum 8 20-04-2004 23:57
Team 524's bot Amadkow Robot Showcase 2 27-02-2002 20:36
Novi Kickoff Seminar List (Tentative) Joe Johnson General Forum 1 05-12-2001 13:47
